| S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-present |
#1 | ||
#2 |
It would be a hard pressed thing to prove that a shortened shifter hieght caused damage to the car. Come on now.
Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic. 2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch StopTech ST-60 BBK - Stratmosphere intake - APR Stage 1 + exhaust **** Have USB HEX-CAN Vag-Com cable if you need someone local to mod you ****
#3 |
If Audi can prove that you had a non-OEM part on the car (even if you put the stock piece back on), and that non-OEM part caused any damage, they can deny that particular claim.
Always remember, no aftermarket part makes the entire warranty void. You can have your driveline modified to the hilt, and if the remote trunk lid does not open properly, it is covered. Like NWS4Guy said, you are probably fine. The ONLY thing i can think of is that if the linkages get damaged due to faulty design of the SS. But that's just a guess..... Wouldn't sweat it... |
#4 |
2011 Audi S4Join Date: Feb 2010
A shifter is a lever. You're simply shortening an arm of the lever and adding a more durable wear surface for the pivot point. A dealer would be hard pressed to prove that it caused a problem short of a bad install causing it to come loose from or detach from the linkage during driving. It would be like trying to deny warranty on the sport diff because you used different wheels.
2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, Nav, Ti Pkg |
#5 |
Thats what I figured... thanks guys.
I know the JHM SS would never damage anything if installed correctly, I guess I'm just a bit paranoid about my first mod. You never know what dealers will try and pull, right? At least now I'll have a formulated response if my dealer tries to say anything about it. |
#6 | |
| Tags |
| audi, jhm, s4, ssk |
