Go Back   AudiWorld Forums > Audi Models > Audi A6 / S6 / RS 6 > A6 / S6 (C6 Platform) Discussion
Old 01-26-2011, 02:19 PM   #1
jhalee0214
Account #: 187476
Default 2006 audi a6 3.2., ECU Reset
I overheard from my friend that I can reset ECU in factory default without going to dealer.
There is a certain procedure (press brake pedal couple times and close the door once something like this..)
Is it possible?
If it is possible, how can I do it? Has anybody done reseting ECU by itself?
Thanks!
jhalee0214 is offline   Reply With Quote
Old 01-26-2011, 07:35 PM   #2
BlueSander
Account #: 155014
I think what your friend was referring to is resetting drive-by-wire system. It's the whole learning your driving style of the car. Regarding the exact procedure, I don't have it on top of my head now but I'm sure a quick search will definitely give you the result.
BlueSander is offline   Reply With Quote
Old 01-26-2011, 08:52 PM   #3
pcamaj
Account #: 194146
i think i reseted mine when i changed my battery couple of days ago lol....
pcamaj is offline   Reply With Quote
Old 01-28-2011, 01:28 PM   #4
gkb
Account #: 167186
for my past cars it's just been unhook battery for a couple minutes 10-20. When I was installing my system in my C6, after plugging back in the battery everything was reset, Gas mileage, memory seats, mirrors, time/date etc. (it's also suppose to clear codes temporarily, however if something was actually fixed then the system will sense the change and permanently remove code) if you didn't fix anything then it will just pop back up when the system senses the same problem. It's what some punks do right before they sell a car with a Check Engine Light.
gkb is offline   Reply With Quote
Old 01-28-2011, 06:22 PM   #5
pcamaj
Account #: 194146
hahah going back to the check engine light, my brother came on a Range Rover HSE, it was something about losing air in the engine or something , so his battery died and when he put a new one back never came back .... almost a year....
Old 01-28-2011, 09:12 PM   #6
gkb
Account #: 167186
haha... lucky. when I had an eclipse tried to outsmart my ECU by resetting it because I needed to change my 02 sensor but I didn't feel like it & got bothered by the light, so I reset it, it worked I laughed hard as hell for 5 mins how there was no more CEL 5 mins later it comes right back on...
Old 01-28-2011, 10:09 PM   #7
pcamaj
Account #: 194146
hahahha, yep sometimes there is no way around it...
Old 11-08-2013, 08:02 AM   #8
Giedrius Baranauskas
Account #: 270514
Default please help
Sunday,27,October,2013,17:33:43:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 72 76 77
VIN: WAUZZZ4F95N072225 Mileage: 235530km/146351miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 1010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 1010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Sporadic communication error 1000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Sporadic communication error 1000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 1010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
Component: 3.0L V6TDI G000AG 0040
Revision: --H01--- Serial number:
Coding: 0011772
Shop #: WSC 02334 785 00200
VCID: 254BEF4DECFA271
3 Faults Found:
19591 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached
Freeze Frame:
RPM: 756 /min
Torque: 42.9 Nm
Speed: 0.0 km/h
Voltage: 14.06 V
Duty Cycle: 89.2 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
Temperature: 77.4°C
17953 - Throttle Valve Controller
P1545 - 002 - Malfunction
Freeze Frame:
RPM: 756 /min
Torque: 31.2 Nm
Speed: 0.0 km/h
Voltage: 13.98 V
Duty Cycle: 22.1 %
Bin. Bits: 000
Mass Air / Rev.: 475.9 mg/str
Voltage: 0.000 V
17979 - Left Engine Mount Solenoid Valve (N144)
P1571 - 001 - Short to Plus
Freeze Frame:
RPM: 777 /min
Torque: 46.8 Nm
Speed: 0.0 km/h
Voltage: 11.86 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Temperature: 53.1°C
Readiness: 1 2 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F0 910 156 H HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0080
Revision: --H01--- Serial number: 0067162
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 2855E6799BE83A9
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
VCID: 2649E84191FC2C9
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300092039
Coding: 0000003
Shop #: WSC 05600 995 82508
VCID: E3CF3155224E191
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H36 0040
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 129
Mileage: 235371 km
Time Indication: 0
Date: 2005.02.17
Time: 09:14:10
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350KP047548222
Coding: 0000000
Shop #: WSC 00000 000 00000
Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
5 Faults Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 182
Mileage: 140529 km
Time Indication: 0
Date: 2010.09.04
Time: 14:03:21
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
00003 - Control Module
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 92
Mileage: 235538 km
Time Indication: 0
Date: 2013.10.27
Time: 17:09:24
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 128
Mileage: 235353 km
Time Indication: 0
Date: 2005.02.14
Time: 15:03:21
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 F
Component: KLIMABETAETIGUNGH04 0110
Revision: 00000023 Serial number: 00000000080703
Coding: 0000022
VCID: DBBF09B51A3E211
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0002122
Shop #: WSC 02335 785 00200
VCID: E6C92841D17C6C9
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
3 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 31
Reset counter: 128
Mileage: 234444 km
Time Indication: 0
Date: 2005.02.01
Time: 15:57:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 56
Reset counter: 132
Mileage: 234444 km
Time Indication: 0
Date: 2005.02.01
Time: 15:57:00
01498 - Bulb for Parking Lamps; Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 132
Mileage: 234872 km
Time Indication: 0
Date: 2005.02.08
Time: 14:48:00
Address 0E: Media Player 1 Labels: None
Part No SW: 4E0 910 119 E HW: 4E0 035 119
Component: CD-Single H41 0330
Revision: 00000000 Serial number: 302FG067530525
Shop #: WSC 66565 257 00032
VCID: 234FF155E2CED91
1 Fault Found:
00468 - CD-ROM Drive (R92)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 2
Reset counter: 128
Mileage: 235345 km
Time Indication: 0
Date: 2005.02.13
Time: 14:05:49
Freeze Frame:
Time: 0.00 ms
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
Component: 32 AIRBAG AUDI8RH29 0250
Revision: 05H29000 Serial number: 0037LD04K0VD
Coding: 0013106
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90022043070206
Coding: 0002041
Shop #: WSC 02323 785 00200
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 S
Component: KOMBIINSTR. M73 H09 0630
Revision: 00400000 Serial number: 4M3547AC4
Coding: 0001143
Shop #: WSC 00999 444 64523
VCID: 1E39C0A1C9ACF49
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804A2001E5
Coding: ECFE73C41B3104
VCID: 2757E54596F6351
7 Faults Found:
00459 - Control Module for Display and Input; Front (J523)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 4
Reset counter: 123
Mileage: 234444 km
Time Indication: 0
Date: 2005.02.01
Time: 14:25:59
02076 - Media Player Position 1 (R118)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 128
Mileage: 234444 km
Time Indication: 0
Date: 2005.02.01
Time: 14:25:59
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 234444 km
Time Indication: 0
Date: 2005.02.01
Time: 14:25:59
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 234444 km
Time Indication: 0
Date: 2005.02.01
Time: 14:25:59
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 234444 km
Time Indication: 0
Date: 2005.02.01
Time: 14:25:59
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 234444 km
Time Indication: 0
Date: 2005.02.01
Time: 14:25:59
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 128
Mileage: 235353 km
Time Indication: 0
Date: 2005.02.14
Time: 15:03:51
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 353K3047588794
VCID: 3B7F29357A7E811
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: ‚W1
Coding: 0000522
Shop #: WSC 02327 785 00200
VCID: 2953E37D80E2031
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 D HW: 4F0 907 289 D
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01001405380000
Coding: 0131205
VCID: 2B5F19758A1E111
1 Fault Found:
00987 - Lamp for Brake Light; Left (M9)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 18
Reset counter: 129
Mileage: 234447 km
Time Indication: 0
Date: 2005.02.02
Time: 00:09:12
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H09 0350
Revision: 16S00001 Serial number: 03009040036983
Coding: 0000002
VCID: 2241F451FDD4D09
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000028721
Coding: 0001003
VCID: DEB900A1092C349
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: 2‡1
Coding: 0000522
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
VCID: DDBB07AD042A2F1
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 C
Component: Dynamische LWR H01 0010
Coding: 0000003
VCID: 3A712C317544B89
1 Fault Found:
00070 - Starting Battery Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 92
Mileage: 234872 km
Time Indication: 0
Date: 2005.02.06
Time: 15:22:21
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 352K 047576781
Coding: 0000001
VCID: 31630B1DA8327B1
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000077095
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1411080111
Coding: 344630393135313035442056413031343131303830313131
Shop #: WSC 12345 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0000002
VCID: 2A511C7185E4089
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0000002
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0030
Revision: --.--.-- Serial number: 11720429900806
Coding: 0001006
VCID: E1C33B5D38520B1
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000006 Serial number: T2AUDX0504HDST
Coding: 0000006
1 Fault Found:
02387 - Telephone Mount (R126)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 132
Mileage: 234897 km
Time Indication: 0
Date: 2005.02.08
Time: 20:30:47
End ---------------------------------------------------------------------
Giedrius Baranauskas is offline   Reply With Quote
Old 11-08-2013, 10:18 AM   #9
hrc4u
Account #: 153562
help with what?...little more info is always good you know..
anyway start by clearing all fault codes first....then scan again..
most listed faults are from like 2005.....
Audi 3.2Q Tiptronic 2005
Mods:
Parking aid+
Audi Ami
MMI5570
Vcds 11.x/HEX-USB+CAN
hrc4u is offline   Reply With Quote
01, 06, 2005, 2006, 27t, 32, a6, audi, check, ecu, engine, light, mirror, quattro, replace, reset
Forum Jump
