Old 01-23-2011, 07:58 PM   #1
daamerikandream1
Account #: 183749
Default key stuck in the ignition switch
Hey guys. I have a serious issue here, my key is stuck in the ignition switch and i have no access to the truck (only have one key) because the key is stuck and the car battery is dead. the only access to the truck is the small panel that opens up for the ski bag. sad to say that i had to cut away the ski bag to see into the trunk but i just cant reach the battery connectors. is there away to remove the key from the ignition? or is there anyway that i can boost the car w/o the plugging up to the actual battery?
daamerikandream1 is offline   Reply With Quote
Old 01-23-2011, 08:19 PM   #2
tashakes
Account #: 184447
tashakes's Avatar
There is a small button on the ignition switch that you can press with a pin and it will let the key slide out.
2007 A8L Brilliant Black/Amaretto, Sport, Premium, Massage/Vent Seats, Daily Driver
1976 BMW 2002 Arktisblau, 4 spd, Sunroof, Daily Money Pit
tashakes is offline   Reply With Quote
Old 01-23-2011, 09:04 PM   #3
Brozee
Account #: 176342
Brozee's Avatar
Probably didn't see it in the rush. Next time before hacking away just give the dealership a call, they could've told you that over the phone.
2007 A8L 6.0L W12 Fully loaded every option
Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, 2011 Maps, MMI v46.1
VCDS Mods: belt chime delete, remote window control.
2005 A8 4.2L w/ all packages.
Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, limo tint, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control.
Popular Topics & Help for Noobies:
Oil Change Procedure
Disable TPMS System
AMI Installation
AMI Update (Phone not pairing)
Remote Window Control
Enable Hidden Menu & Enable Battery Meter
Fog Light Replacement
City Light Bulb Replacement
Door, Trunk, & Glove Box LED Change
Cabin Air Filter Change
Maintenance & Common Problems
Brozee is offline   Reply With Quote
Old 01-23-2011, 11:42 PM   #4
kabre
Account #: 177456
You can get battery chargers that have a cigarette lighter connection, so you could trickle charge the car through that which should get the electrics working again.
kabre is offline   Reply With Quote
Old 01-24-2011, 04:18 AM   #5
williebone
Account #: 179840
williebone's Avatar
Pull out your Owner's Manual it's in there. There is a Small Cover that needs to be removed First and then just use something Pointed to Release the Key. Get a Battery Charger so that this doesn't happen to you again. Good luck and laters,
Brilliant Blk/Blk 04' A8L D3 (Sports & Cold Weather Convenience Pkg) Click Photo
Inside Mods: Custom Intergrated Sound System & Speakers/Custom Gray A8 Mats/Gray A8 Shldr Pads/Gray Leather Seat Strip Overlays/MMI & Nav Update/Outside Mods: Germany Sport Badges/Light Smoke Tinted Lighting/Rear Roof Glass & Rear Lip Spoiler/3"x 4" Slanted Oval Exhaust Tips/DDM HID Fogs/LED Lighting: Parks,Courtesy,License Plt & Trunk/Polish Black Carbon Fiber Wrap/Custom Zinc Silver Drill-Slotted Blk Hub Rotors/EBC Red Pads/Red 2pt Epoxied Calipers/H&R Spacers: 20mm Bolt On Rear & 15mm Front/Chrome Headlight Trim/Wheels: 19" Pirellis/Rims: 19" Hyper Blk Machine Faced 5 Spoke Triple Wishbone AMG Reps (No Logo!)/Vag-Com Mods: Lowered 20mm Frt & 10mm Rear/Fogs w/out HIDs/Remote Open-Close Windows & Roof/Double Chirp
Previously Owned: 01' Ming Blue D2 w/Polished Turbines & Sound System Mod Upgrade
Joined The A8L 4 Ring Circus Act Known As Ming Blue The Brilliant Black Beast!
williebone is offline   Reply With Quote
Old 01-24-2011, 05:20 AM   #6
Mister Bally
Account #: 102428
Since you already cut the ski sack away, can't you operate the "kid is stuck in the trunk" lever on the road side interior of the trunk lid? It is glow in the dark. A looooong broom handle or remote paint roller extension or some kind of gardening tool you might have can be used.
Just a thought.
Mister Bally is offline   Reply With Quote
Old 01-24-2011, 06:02 AM   #7
Mike141
Account #: 62852
Just a thought.
Or I can give you my trunk latch that doesn't latch when the temp is below 30!
Mike141 is online now   Reply With Quote
Old 01-24-2011, 07:47 AM   #8
Mister Bally
Account #: 102428
We've covered that on this thread before. I've opened mine up (the latch drive assembly), cleaned up all of the grease and regreased the spline and gear assembly. I used old fashioned MBI instrument grease. However, Lubriplate white grease should be just as good. Lubriplate grease is sold at Home Despot(sic) in the Genie® garage door opener parts section as screw drive lubricant.
Or, [sarcasm on] go the s4master1 route and replace the assembly. You can have your A8L flatbedded to his shop in Culver City, CA (fee applies) like a couple of his customers do or just take it to a shop. His shop sees about 20 A8's a month so he's gotta be doing something right [sarcasm off].
Old 01-25-2011, 08:41 AM   #9
daamerikandream1
Account #: 183749
Thanks everyone for your help, my local dealer isnt very friendly with advice. But wish i would have read the book b4 killing the ski bag although bc i cut it so clean n close i think it could be reattached. That little button worked used a toothpick and it worked like a charm.
Old 01-25-2011, 09:03 AM   #10
A8nightmare
Account #: 203864
Default key stuck issue
I had the same problem. Mine is an 05 model, but that year does not have the little hole to remove the key manually. Since you cut out the ski pack just use the child locked in trunk lever and open it that way. Good luck!!
A8nightmare is offline   Reply With Quote
1997, 2003, a4, a6, a8, audi, car, grease, ignition, instrumant, instrument, key, kill, lubricate, mbi, stuck
Forum Jump
