Go Back   AudiWorld Forums > Audi Models > Audi A4 > A4 (B7 Platform) Discussion
Old 01-16-2011, 05:18 PM   #1
SomeNoobie
Account #: 201664
Default Vacuum Leak - P0171/P0507
I am quite the noobie when it comes to automotive repair; I know trucks and especially military vehicles, but never a European car like my wifeís Audi. Right now I face the problem of a vacuum line or something of the like. I am getting the error codes:
P0171 - System too lean; low fuel pressure or volume; Probable cause: 1. Faulty HO2S, 2. Large vacuum leak, 3. Faulty MAF sensor
P0507 - Idle Air control system RPM higher than expected; Large vacuum leak on engine: Probable cause 1. Throttle plate misadjusted or damaged 2. Faulty IAC valve
Some back ground: Weather has gone from moderate to sub-temperatures; the car is parked in the garage every night, in a parking garage during the day, driven 40 minutes total per day. It is a 2007 Audi A4 2.0T with 82,000 miles.
I am attempting to locate, the vacuum tubes but I am not quiet sure what I need to look for. All the places I look online are kind of cryptic and donít do a great job at describing what to look for. If anyone has a good large res explosion chart of the vacuum tubes, Throttle plate, MAF sensor it would be of great help.
-or-
If anyone has an idea as to what I can do to fix my problem, I would be indebted to you.
Thank you.
SomeNoobie is offline   Reply With Quote
Old 01-16-2011, 06:36 PM   #2
mscav
Account #: 95442
Those codes could mean a bad pressure regulator valve (PCV). It's a common problem on these engines. Same codes I had, and others on this forum.
Pull off the plastic engine cover and you'll see it. Looks like this:
http://i25.photobucket.com/albums/c5...y/DSCF1138.jpg
mscav is offline   Reply With Quote
Old 01-16-2011, 08:19 PM   #3
MikekiM@PureMS
Audiworld Premium Sponsor
Account #: 13830
I'd double check your cam follower.
www.purems.com
866-397-5487 | San Diego, CA | mike@purems.com | Specials on Twitter!
MikekiM@PureMS is offline   Reply With Quote
Old 03-03-2011, 07:18 AM   #4
mrsaynomo
Account #: 209124
Were is the Best Place to Buy the PVC Valve ?
mrsaynomo is offline   Reply With Quote
Old 03-03-2011, 11:29 AM   #5
oaktreelimb
Account #: 166606
got it at dealer so you will get a latest version of crank case pressure regulator.
Try to pull oil filler cap while engine at idle. If it is so hard to pull the cap, the crank case pressure regulator valve is the most likely problem.
oaktreelimb is offline   Reply With Quote
Old 03-11-2011, 03:22 PM   #6
suicideking
Account #: 196812
where is this crank case pressure regulator valve located?
suicideking is offline   Reply With Quote
Old 03-11-2011, 04:14 PM   #7
suicideking
Account #: 196812
what does the cam follower have to do with this?
Old 03-15-2011, 11:27 AM   #8
oaktreelimb
Account #: 166606
Crank case pressure regulator valve is mounted on valve cover and has two hoses connected to it.
Old 07-20-2012, 05:24 PM   #9
Ronnier A Rodriguez
Account #: 239749
Default Crankcase pressure regulator valve
Which one of these is the updated one, http://www.partsgeek.com/catalog/200...ent_valve.html . I'm having the same idling issues and I'm not sure if the regulator valve should be blowing air out of it at such a high sound. It only happens when I am parked.
Ronnier A Rodriguez is offline   Reply With Quote
Old 07-23-2012, 02:54 AM   #10
audi01a6
Account #: 98906
-or-
Thank you.
there is a tsb on that,also on flap motor,possable fuel pressure ck valve too,give your vin# to your dealership and see what happens,should be free under warrt.,hope that helps,
audi01a6 is offline   Reply With Quote
18t, 2005, 20t, a4, audi, code, codes, engine, error, fsi, fuel, leaks, low, oil, p0171, p0507, pressure, sensor, vacuum
Forum Jump
