Go Back   AudiWorld Forums > Audi Models > Audi A6 / S6 / RS 6 > A6 / S6 (C6 Platform) Discussion
Old 01-14-2011, 04:58 AM   #1
vlam04
Account #: 170912
Default 2006 A6 P2006 P2007 Error Code
Hey gang,
So my check engline light came on and I had my indie look at it. they do a pretty good job and are reasonably priced. he said that the error code is p2006 and p2007 which is related to the intake flaps not opening or there is a vacuum leak somewhere involving the inlet manifold. he said that the drive unit for it is malfunctioning. the part alone is like $350! part number is 06e-133-619. and to install it is like $225. i didn't realize this was going to be so hard to install that the price would be so high.
has anyone else had this problem? i read somewhere that this could also be related to carbon build up inside the engine and that our 3.2 engines are notorious for carbon build up. boooo!!!
-van
vlam04 is offline   Reply With Quote
Old 01-14-2011, 09:38 PM   #2
A6Gary
Account #: 49976
You can purchase that OEM part on–line for $259.20 + $5.95 shipping from audipartsnationwide.com (Rector Audi). BTW, I have not had any issues (at least not yet) with my 2006 A6 Avant w/ 43K miles on it.
A6Gary is offline   Reply With Quote
Old 01-17-2011, 06:01 AM   #3
badziewo
Account #: 186983
I had exactly the same problem code P2006, P2007.
One of the vacuum pipe in the front of the engine was cracked.
The pipe cost me $21 from audi
badziewo is offline   Reply With Quote
Old 01-18-2011, 07:36 AM   #4
vlam04
Account #: 170912
hey badziewo or anyone else.... do you know where i can locate the vacuum line? my i'm hoping it's just the hose or vacuum line that i can inspect myself.
Old 01-19-2011, 05:25 PM   #5
badziewo
Account #: 186983
The vacuum pipes are located under the front engine plastic cover.Check the TSB attachment
Old 02-04-2012, 12:23 PM   #6
rgarretson
Account #: 175160
rgarretson's Avatar
Thanks guys, with your thread I was able to search for the proper vacuum hoses and sure enough, I had a broken hose. Havent fixed it just yet but now I know. I had Fault codes P2006 and P2007.
2005 A6 3.2 Quattro
Brilliant Black/Black, NAV, Sunroof, Premium Package, Technology Package
rgarretson is offline   Reply With Quote
Old 02-04-2012, 01:29 PM   #7
ezveedub
Account #: 89002
ezveedub's Avatar
Check the entire length of the vacuum lines, as they break over on the driver's side front area of the cylinder head also. You can generally clip the brittle section out and use a rubber vacuum hose in that area instead.
ezveedub is offline   Reply With Quote
Old 02-10-2012, 03:35 AM   #8
rgarretson
Account #: 175160
rgarretson's Avatar
Hey guys, Quick question. I took the advie and replaced the entire length of the side that I found broken with heat resistant silcone/rubber hose. It might be my imagination but the car appears to respond better however the engine light did not go off on its own. Do I need to get the codes cleared or will the light go off on its only after a little while?
Thanks
2005 A6 3.2 Quattro
Old 02-10-2012, 04:10 PM   #9
MaydayNY
Account #: 225264
Same thing happened to me. Took about a day, but the light eventually went out on its own.
MaydayNY is offline   Reply With Quote
Old 04-29-2012, 05:16 PM   #10
Fitness09
Account #: 235097
Default Looking at a 2006 A6
I am currently looking at purchasing an Audi A6, but wanted to get a take from some owners. It is a 2006 3.2 and looks to have all the options. However, there are some problems. It has 71k miles on it, it is sending the code about the cracked hose mentioned in this thread, one rear light is out, the passenger side window will roll down, but not up from the driver side(it will from the passenger side door), and the air bag light is on. The girl who currently own the car said the airbag light has come on and off since she bought it.
This is a pretty nice vehicle, but I don't want to buy a problem. Thanks for the help.
Fitness09 is offline   Reply With Quote
07, 2005, 2006, 2007, a6, audi, code, codes, ecu, engine, error, fault, number, p2006, p2007
Forum Jump
