| A4 (B5 Platform) Discussion Discussion forum for the B5 Audi A4 produced from 1995-2001 B5 FAQ |
#21 | |||
#22 |
I do not think it was a mistake because the indicator is working well, but reversed, if the fuel sender out and move it up and down, move the pointer. And in the instrument cluster, a single wire coming from the sender, because the other one is ground. Thanks for the reply
#23 |
which cluster do you have 1 or 2 originally and which one did you install ?
Here in North America early A4 came in 1996 and had cluster 1 |
#24 |
My first cluster was cluster number 1 and now I have cluster number 2 and this custer have immo inside if it matters
#25 |
Here is a pin assignment from Cluster 1
Instrument Cluster Multi-Pin Connector Terminal Assignments, through MY 1997 26-Pin Connector, Blue 1 - Open 2 - Signal for buzzer 3 - Terminal 15 4 - Terminal 15 5 - Open 6 - Terminal 61 7 - Parking brake/brake system malfunction 8 - ABS (input signal) 9 - Airbag (input signal) 10 - CAT 11 - Open 12 - Open 13 - Parking light, right 14 - Ignition switch, S-contact 15 - Chime signal 16 - Open 17 - Open 18 - Oil pressure 1.8 bar 19 - Terminal 58d 20 - Coolant level 21 - Turn signal, right 22 - Headlight high beams 23 - Speedometer Vehicle Speed Sensor (VSS) (checking → Chapter) 24 - Brake fluid 25 - Brake pads 26 - Parking light, left 26-Pin Connector, Yellow 1 - Terminal 58 2 - Terminal 58 3 - Engine RPM signal 4 - Air conditioner compressor 5 - Clock (output) 6 - Speed signal 1 7 - Speed signal 2 8 - Door contact (driver's door) 9 - Terminal 30 10 - Terminal 30 11 - Open 12 - Fuel tank warning 13 - Turn signal, left 14 - Open 15 - Open 16 - Seat belt buckle switch 17 - Open 18 - Terminal 31 19 - Terminal 31 20 - Diagnostic wire 21 - Open 22 - Open 23 - Open 24 - Open 25 - Sender for fuel gauge Checking → Chapter 26 - Engine coolant temperature sensor Checking → Chapter 20-Pin Connector, Black 1 - Fuel consumption signal 2 - Open 3 - Open 4 - Open 5 - Outside air temperature 6 - Selector lever display 7 - Open 8 - Open 9 - Coolant level 10 - Hydraulic pressure 11 - Trip computer - Reset 12 - Radio/Telephone - Clock 13 - Radio/Telephone - Data 14 - Trip computer (forward sequence) 15 - Radio/Telephone - Enable 16 - Rear lights/headlight low beams 17 - Open 18 - Trip computer (reverse sequence) 19 - Brake lights 20 - Open 4-Pin Connector, Black 1 - Oil temperature sensor 2 - Open 3 - Open 4 - Open |
#26 |
here is for cluster 2
Instrument Cluster Terminal Assignments, cluster 2 32-Pin Connector for Basic Functions, Blue 1 - Terminal 15 2 - Turn signal, right 3 - Speedometer output 1 4 - Open 5 - Sender for fuel gauge 6 - Airbag 7 - Terminal 31 sensor Ground (GND) 8 - Coolant temperature 9 - Terminal 31 load Ground (GND) 10 - Oil pressure switch 11 - Engine speed (RPM) signal 12 - Terminal 61 13 - CAT 14 - Self leveling suspension 15 - Terminal 58d 16 - Malfunction Indicator Lamp (MIL) 17 - High beam 18 - Turn signal, left 19 - ABS 20 - Terminal 58s 21 - Door contact (driver's door) 22 - Engine coolant low 23 - Terminal 30 24 - Terminal 31 load Ground (GND) 25 - K-wire 26 - Parking light, right 27 - Parking light, left 28 - Speedometer (input) 29 - Brake fluid level/pressure 30 - S-contact 31 - Seat belt buckle 32 - Electronic Stability Program (ESP) 32-Pin Connector for Additional Functions, Green 1 - Open 2 - Open 3 - Open 4 - Open 5 - W-wire 6 - Tailgate (Lowline model only) 7 - Brake pad (Highline model only) 8 - Input for outside buzzer control (currently not assigned) 9 - Input for outside chime control (currently not assigned) 10 - Low fuel level warning-output signal for Engine Control Module (ECM) 11 - Standing time output 12 - Air conditioning cutout 13 - Parking brake 14 - Electronic throttle 15 - Side marker light 16 - Open 17 - Open 18 - Open 19 - Open 20 - Open 21 - Oil temperature 22 - Open 23 - Open 24 - Open 25 - Open 26 - Open 27 - Open 28 - Open 29 - Open 30 - Speedometer output 2 31 - Open 32 - Open 20-Pin Connector for Multi-Function Display, Red 1 - Fuel consumption signal 2 - Open 3 - Open 4 - Open 5 - Outside air temperature 6 - Selector lever display 7 - Open 8 - Open 9 - Washer fluid 10 - Hydraulic pressure 11 - Trip computer reset 12 - Clock signal for radio frequency display 13 - Data signal for radio frequency display 14 - Trip computer (forward sequence) 15 - Enable signal for radio frequency display 16 - Tail lights/headlight low beam (indicator lights) 17 - Open 18 - Trip computer (reverse sequence) 19 - Brake lights 20 - Open |
#27 |
here is for cluster 3
Blue 32-Pin Multi-Pin Connector for Basic Functions 1 - Terminal 15 2 - Brake pad wear 3 - Tachometer output 1 4 - not occupied 5 - Tank sensor 6 - Tank warning OBD 2 7 - Terminal 31 (sensor Ground (GND)) 8 - Coolant temperature 9 - Terminal 31 (load Ground (GND)) 10 - Oil pressure 2 (high) 11 - RPM signal 12 - A/C shut-off 13 - E-Gas/glow plug control 14 - Level control 15 - Terminal 58d 16 - Trailer turn signal 17 - High beam 18 - Left turn signal 19 - not occupied 20 - Terminal 58s 21 - Driver door contact 22 - Low coolant 23 - Terminal 30 24 - Terminal 31 (load Ground (GND)) 25 - Consumption signal 26 - Right parking light 27 - Left parking light 28 - Tachometer input 29 - Brake 30 - S-contact 31 - Tachometer output 2 32 - ESP/ASR Green 32-Pin Multi-Pin Connector for Auxiliary Functions 1 - Door contact (all doors) 2 - Transponder 1 3 - not occupied 4 - not occupied 5 - W-wire 6 - Tailgate 7 - Right turn signal 8 - External buzzer 9 - External gong 10 - Airbag 11 - Stand-still time output 12 - Terminal 61 13 - Parking brake/BRAKE 14 - CHECK 15 - Oil level/oil temperature 16 - not occupied 17 - Transponder 2 18 - CAN high speed (powertrain) (high +) 19 - CAN high speed (powertrain) (low -) 20 - CAN high speed (powertrain) (screen) 21 - ABS 22 - CAN low speed (comfort) (high +) 23 - CAN low speed (comfort) (low -) 24 - CAN low speed (comfort) (screen) 25 - Engine lid 26 - not occupied 27 - Belt buckle 28 - K-wire 29 - Outside temperature -input 30 - not occupied 31 - Selector range display 32 - not occupied Gray 32-Pin Multi-Pin Connector for Multi-Function Display 1 - Menu selection switch (menu) 2 - Menu selection switch (out A) 3 - Menu selection switch (out B) 4 - Menu selection switch (Enter) 5 - CAN high speed display (high +) 6 - CAN high speed display (low -) 7 - CAN high speed display (screen) 8 - Passenger door contact 9 - Right rear door contact 10 - Left rear door contact 11 - Enable 12 - Clock 13 - Data 14 - Brake light 15 - Windshield washer fluid level 16 - Rear lights/low beams 17 - Left board computer 18 - Right board computer 19 - Board computer, reset 20 - not occupied 21 - not occupied 22 - not occupied 23 - Button branch 1 navigation 24 - Button branch 2 navigation 25 - Button branch Telematic 26 - not occupied 27 - not occupied 28 - not occupied 29 - not occupied 30 - not occupied 31 - not occupied 32 - not occupied Hopefully that will answer most questions for pin assignment |
#28 |
i have the pinout thanks
#29 |
Welcome!
A4 cluster fit in audi80 B4? |
#30 |
Hi!
I´m new to this forums, but i have a quick question! I have a -97 A4, with cluster number 1, but without the LCD and with 4 gauges... Is it possible to swap it for a -98 cluster with 6 gauges and LCD? |
| Tags |
| 1996, 1997, 20015, 503a, 8d9, 953, 97, 995, a4, a5, audi, bus, cluster, difference, immobilizer, upgrade |
