Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 01-05-2011, 01:28 PM   #1
audifirst
Default Understanding differences between Audi A4 clusters and the compatibility issues
Disclaimer. The information on this post is for informational purposes only.
This post and all of the information it contains are provided 'as is' without warranty of any kind, whether express or implied.
The wiring information was taken from "Bentley Publishers CD and Hardcover copy", there may be omissions or inaccuracies in information contained in this post. Before making any decision or taking any action based on the information contained in this Post, you should double/triple check information regards to the vehicle you service.
If you found that the information is inaccurate and you have found the solution post it up and I will update the post.
*updated May 01, 2012* additional information provided by MetalMan
Couple people ask me if I can show the difference between instrument clusters from 1996 to 2001.5
The photo below shows all 3 instrument clusters from 1996 to 2001.5 with Full size LCD, some models didn't come with LCD screen because of the package was not selected during order back then.
Here is the back of the instrument clusters.
You can see the difference between all the clusters the cluster 1 is CDN or European but MPH is identical except speedometer is in MPH the other two are MPH clusters I had,
Cluster 1 was installed in 1996 and 1997 Audi A4 early models , no immobilizer the most visible difference is if you look at the analog clock has no digits at 3, 6, 9, at 12 o'clock comparing to cluster 2
Cluster 2 was installed in 1998 to 1999.5 Audi A4 models, , you could swap cluster between these years with no issues, no immobilizer.
Cluster 3 was installed in 2000 to 2001.5 Audi A4 models,some 99.5's with VIN > 8DY000001 had cluster with digital clock, the main difference was the analog clock was replaced with digital clock to match the mileage LCD, and in late 2001 immobilizer was added to system
NOW COMPATIBILITY
Legend
  • Cluster 1 is 1996-1997 (no immobilizer, no Can-Bus)
  • Cluster 2 is 1998-1999.5 (no immobilizer, no Can-Bus)
  • Cluster 3 is 2000 to 2001.5 (00 had no immobilizer but Can-Bus was introduced, 01+ had Immobilizer and Can-Bus)
Cluster 2, and cluster 3 can not fit directly into cluster 1, because cluster 1 has different plugs , in order to fit you need to buy new plugs and new pins and rewire some connection.,
I know two people who proceed with this conversion one did the cluster 2 to cluster 1 and had partially working cluster,
all the gauges were working however compatibility was an issue and error code were reported cluster did not understand modules in the car, other did cluster 3 to cluster 1 and had only partial success two gauges were working , all the lights were lit up like Christmas tree .
Cluster 3 can be installed into cluster 2 however some rewiring is required to both blue and green plugs and the middle plug from cluster 3 doesn't fit cluster 2 which you need to rewire as well,
regards to immobilizer on some early 2001 clusters this feature can not be disabled in the instrument cluster the little car key will flash some people cover it with electrical tape, but it will beep at start up for 3 seconds.
Also Can Bus was introduced in some early 2000+ models which meant that vehicle in 1998-1999 didn't have can-bus and some clusters from 2001-2001.5 didn't work the tachometer or speedometer was not functional
If you really want to have digital clock in 1998-1999 A4 model try to get 1999.5 to 2000 instrument cluster that don't have immobilizer or Can-Bus requirement.
Cluster 3 with immobilizer will work in early cluster 3 however immobilizer light will be present during start and will flash continuously and it will beep for 3 seconds during start up.
If your car came originally without center LCD , you can swap the cluster with LCD however in order to change menus you need to buy new wiper arm with switch and wiring and add wires between the cluster and wiper arm
you will need the wiper control arm that has a switch at the end wiper arm to change menus on center LCD
for 1996 to 1997 Cluster 1
you need wiper arm
part# 8D9 953 503 A (sedan)
part# 8D9 953 503 C (Avant)
for 1998 to 2001.5 Cluster 2, and Cluster 3
Part# 4D0 953 503 B (sedan)
part# 8D0 953 503 D (Avant)
There are 3/4 sets of wires required for wiper arm control harness plug and for the instrument cluster harness plug for the Grey Connector on
Cluster 3, and red connector of Cluster 2 , black connector on cluster 1
I recommend to buy wires from Audi/VW dealer
On cluster 1
You need to insert wires into black 20 pin connector on instrument cluster and to 6 pin harness plug on the wiper arm
Black connector Pin 11 to wiper arm pin 1
Black connector Pin 14 to wiper arm pin 3
Black connector Pin 18 to wiper arm pin 4
Pin 2 on the wiper arm is ground
Pins 5, 6 are not used
On cluster 2
-added a wire between the longer ECU connector, pin 17 (yellow wire), to pin 1 on the RED instrument cluster connector
-grounded pins 9, 16, 19 on the RED instrument cluster connector since I don't need bulb out warnings or low washer fluid warning (this worked)
You need to insert wires into red 20 pin connector on instrument cluster and to 6 pin harness plug on the wiper arm
Red connector Pin 18 to wiper arm pin 1
Red connector Pin 14 to wiper arm pin 2
Red connector Pin 11 to wiper arm pin 4
Pin 3 on the wiper arm is ground , I just made a short segment and connected it to the wire coming off Pin 5
Pin 5: ground for the intermittent wiper selector on top of the wiper arm
Pin 6: feedback wire for position of the intermittent wiper selector
For people who have a no-LCD cluster, pins 5 and 6 on the wiper arm will already exist, and they are supposed to exist while using the LCD cluster too. They should not be removed.
Cluster 3
you need to insert wires into Grey connector on the instrument cluster and to 6 pin harness plug on the wiper arm
Grey Connector pin 17 to wiper arm pin 4
Grey Connector pin 18 to wiper arm pin 3
Grey Connector pin 19 to wiper arm pin 1
How do I know if my cluster has immobilizer ?
Answer regards Color LCD
Here are Pin out for clusters with Full Size LCD
cluster 1
26-Pin Connector, Blue
1 - Open
2 - Signal for buzzer
3 - Terminal 15
4 - Terminal 15
5 - Open
6 - Terminal 61
7 - Parking brake/brake system malfunction
8 - ABS (input signal)
9 - Airbag (input signal)
10 - CAT
11 - Open
12 - Open
13 - Parking light, right
14 - Ignition switch, S-contact
15 - Chime signal
16 - Open
17 - Open
18 - Oil pressure 1.8 bar
19 - Terminal 58d
20 - Coolant level
21 - Turn signal, right
22 - Headlight high beams
23 - Speedometer Vehicle Speed Sensor (VSS) (checking → Chapter)
24 - Brake fluid
25 - Brake pads
26 - Parking light, left
26-Pin Connector, Yellow
1 - Terminal 58
2 - Terminal 58
3 - Engine RPM signal
4 - Air conditioner compressor
5 - Clock (output)
6 - Speed signal 1
7 - Speed signal 2
8 - Door contact (driver's door)
9 - Terminal 30
10 - Terminal 30
11 - Open
12 - Fuel tank warning
13 - Turn signal, left
14 - Open
15 - Open
16 - Seat belt buckle switch
17 - Open
18 - Terminal 31
19 - Terminal 31
20 - Diagnostic wire
21 - Open
22 - Open
23 - Open
24 - Open
25 - Sender for fuel gauge
26 - Engine coolant temperature sensor
20-Pin Connector, Black
1 - Fuel consumption signal
2 - Open
3 - Open
4 - Open
5 - Outside air temperature
6 - Selector lever display
7 - Open
8 - Open
9 - Coolant level
10 - Hydraulic pressure
11 - Trip computer - Reset
12 - Radio/Telephone - Clock
13 - Radio/Telephone - Data
14 - Trip computer (forward sequence)
15 - Radio/Telephone - Enable
16 - Rear lights/headlight low beams
17 - Open
18 - Trip computer (reverse sequence)
19 - Brake lights
20 - Open
4-Pin Connector, Black
1 - Oil temperature sensor
2 - Open
3 - Open
4 - Open
cluster 2
32-Pin Connector for Basic Functions, Blue
1 - Terminal 15
2 - Turn signal, right
3 - Speedometer output 1
4 - Open
6 - Airbag
7 - Terminal 31 sensor Ground (GND)
8 - Coolant temperature
9 - Terminal 31 load Ground (GND)
10 - Oil pressure switch
11 - Engine speed (RPM) signal
12 - Terminal 61
13 - CAT
14 - Self leveling suspension
15 - Terminal 58d
16 - Malfunction Indicator Lamp (MIL)
17 - High beam
18 - Turn signal, left
19 - ABS
20 - Terminal 58s
21 - Door contact (driver's door)
22 - Engine coolant low
23 - Terminal 30
24 - Terminal 31 load Ground (GND)
25 - K-wire
26 - Parking light, right
27 - Parking light, left
28 - Speedometer (input)
29 - Brake fluid level/pressure
30 - S-contact
31 - Seat belt buckle
32 - Electronic Stability Program (ESP)
32-Pin Connector for Additional Functions, Green
1 - Open
2 - Open
3 - Open
4 - Open
5 - W-wire
6 - Tailgate (Lowline model only)
7 - Brake pad (Highline model only)
8 - Input for outside buzzer control (currently not assigned)
9 - Input for outside chime control (currently not assigned)
10 - Low fuel level warning-output signal for Engine Control Module (ECM)
11 - Standing time output
12 - Air conditioning cutout
13 - Parking brake
14 - Electronic throttle
15 - Side marker light
16 - Open
17 - Open
18 - Open
19 - Open
20 - Open
21 - Oil temperature
22 - Open
23 - Open
24 - Open
25 - Open
26 - Open
27 - Open
28 - Open
29 - Open
30 - Speedometer output 2
31 - Open
32 - Open
20-Pin Connector for Multi-Function Display, Red
2 - Open
3 - Open
4 - Open
7 - Open
8 - Open
9 - Washer fluid
11 - Trip computer reset
12 - Clock signal for radio frequency display
13 - Data signal for radio frequency display
15 - Enable signal for radio frequency display
16 - Tail lights/headlight low beam (indicator lights)
17 - Open
19 - Brake lights
20 - Open
Cluster 3
Blue 32-Pin Multi-Pin Connector for Basic Functions
1 - Terminal 15
2 - Brake pad wear
3 - Tachometer output 1
4 - not occupied
5 - Tank sensor
6 - Tank warning OBD 2
7 - Terminal 31 (sensor Ground (GND))
9 - Terminal 31 (load Ground (GND))
10 - Oil pressure 2 (high)
11 - RPM signal
12 - A/C shut-off
13 - E-Gas/glow plug control
14 - Level control
15 - Terminal 58d
16 - Trailer turn signal
17 - High beam
18 - Left turn signal
19 - not occupied
20 - Terminal 58s
21 - Driver door contact
22 - Low coolant
23 - Terminal 30
24 - Terminal 31 (load Ground (GND))
25 - Consumption signal
26 - Right parking light
27 - Left parking light
28 - Tachometer input
29 - Brake
30 - S-contact
31 - Tachometer output 2
32 - ESP/ASR
Green 32-Pin Multi-Pin Connector for Auxiliary Functions
1 - Door contact (all doors)
2 - Transponder 1
3 - not occupied
4 - not occupied
5 - W-wire
6 - Tailgate
7 - Right turn signal
8 - External buzzer
9 - External gong
10 - Airbag
11 - Stand-still time output
12 - Terminal 61
13 - Parking brake/BRAKE
14 - CHECK
15 - Oil level/oil temperature
16 - not occupied
17 - Transponder 2
18 - CAN high speed (powertrain) (high +)
19 - CAN high speed (powertrain) (low -)
20 - CAN high speed (powertrain) (screen)
21 - ABS
22 - CAN low speed (comfort) (high +)
23 - CAN low speed (comfort) (low -)
24 - CAN low speed (comfort) (screen)
25 - Engine lid
26 - not occupied
27 - Belt buckle
28 - K-wire
29 - Outside temperature -input
30 - not occupied
31 - Selector range display
32 - not occupied
Gray 32-Pin Multi-Pin Connector for Multi-Function Display
1 - Menu selection switch (menu)
2 - Menu selection switch (out A)
3 - Menu selection switch (out B)
4 - Menu selection switch (Enter)
5 - CAN high speed display (high +)
6 - CAN high speed display (low -)
7 - CAN high speed display (screen)
8 - Passenger door contact
9 - Right rear door contact
10 - Left rear door contact
11 - Enable
12 - Clock
13 - Data
14 - Brake light
15 - Windshield washer fluid level
16 - Rear lights/low beams
17 - Left board computer
18 - Right board computer
19 - Board computer, reset
20 - not occupied
21 - not occupied
22 - not occupied
23 - Button branch 1 navigation
24 - Button branch 2 navigation
25 - Button branch Telematic
26 - not occupied
27 - not occupied
28 - not occupied
29 - not occupied
30 - not occupied
31 - not occupied
32 - not occupied
Wiper Switch Pin, Terminal Assignments
A - 6-pin connector
1 - Board computer, reset
2 - Board computer, Terminal 31
3 - Board computer, right rocker switch
4 - Board computer, left rocker switch
5 - open
6 - open
B - 13-pin harness connector
1 - Wiper switch, terminal J
2 - Wiper switch, terminal 53 c
3 - Emergency light (hazard light) switch, terminal R
4 - Wiper switch, terminal 53 b
5 - Wiper switch, terminal 53 a
6 - Emergency light (hazard light) switch, terminal L
7 - Emergency light (hazard light) switch, terminal 49 a
8 - Wiper switch, terminal 53 e
9 - Wiper switch, terminal 53
If you have questions please post them here and I will answer them to best of my ability.
audifirst is offline   Reply With Quote
Old 01-05-2011, 03:25 PM   #2
Reggie
AudiWorld Expert
2011 Audi Q5
My Garage
Reggie's Avatar
Many thanks
Reggie is offline   Reply With Quote
Old 01-05-2011, 04:48 PM   #3
Bronco Joe
I've actually got an early 98 (30v but also has side airbags) and it has cluster #1. As far as I know it's never been switched and I have complete records (I'm the second owner). So, perhaps a few '98s got the first cluster as well?
Bronco Joe is offline   Reply With Quote
Old 01-05-2011, 05:05 PM   #4
moloveshisaudi1254
That is the best Instrument cluster compatibility guide I have seen. Nice job.
I have a 1996 A4 with cluster one but without the LCD. Can you provide clearer steps to retrofit cluster-1 into my car and the part number for the cluster and the new wiper lever with the trip computer controls on it?
-Thank you.
1996 A4 Quattro, 12v V6 (AFC)
moloveshisaudi1254 is offline   Reply With Quote
Old 01-05-2011, 06:23 PM   #5
xsrfsno225x
Thanks man. Its nice to see someone compiling valuable information. People like you make these forums worth it
xsrfsno225x is offline   Reply With Quote
Old 01-05-2011, 06:47 PM   #6
audifirst
-Thank you.
I will post part# tomorrow for conversion into LCD cluster
Old 01-05-2011, 06:55 PM   #7
audifirst
that is true that very early 1998 had parts from 1997 year model ex:cluster/fenders with Audi logo, taillights with amber lights, a
those that have 1997 1.8T were actual 1998 models
same for
1999.5 to early 2000 had mixed parts from pre-face lift model
Audi did a lot of mix up in those days, lot of hybrids
Old 01-06-2011, 05:40 AM   #8
quattromano
Default Well Done!!! Thank you.
I wish I had your guide when I bought a back up cluster for my early 99.5 Avant. Damn LCD pixel problem has struck! Bought a 97 cluster but lo & behold it would not fit!
quattromano is offline   Reply With Quote
Old 01-06-2011, 04:16 PM   #9
mtroxel
mtroxel's Avatar
Nice write up. Great info, and timely. I didn't think Audi did immobilizers till the B6. I just bought an 01 Avant I'm doing a lot of work on. How do I know if it has immobilizer? Will that little key thing show up (after I get the dashboard back together that is)?
99.5 A4 Q 2.8 - 179,000 miles
Hibiscus Red Mica
mtroxel is offline   Reply With Quote
Old 01-06-2011, 05:28 PM   #10
audifirst
If you turn your ignition on no engine look at the tachometer in between 6k to 7k rpm
if the car with little key lights up for second or two you have immobilizer , other way to check is to access instrument cluster menu with VAGCOM, look at the middle section you should see VIN# with 14 digit combination number/letters, then you have immobilizer, if you don't have then you don't have immo, the last check is if you remove instrument cluster and look at the right top edge there is sticker with part# under the part there is 14 digit number usually start with AUZ....... if the rest of the numbers are zeros you don't have immo if it shows combination of numbers and letters then you have immo
i will add this to the post above
1996, 1997, 20015, 503a, 8d9, 953, 97, 995, a4, a5, audi, bus, cluster, difference, immobilizer, upgrade
