| A4 (B6 Platform) Discussion Discussion forum for the B6 Audi A4 produced from 2002-2005 |
#1 | ||
#2 |
Your wipers have "slipped". Not sure where you live, but I had the wipers on a Nissan do this once. Take a look at the link for some specifics.
http://www.audizine.com/forum/showth...ghlight=wipers |
#3 |
Audiworld Basic Sponsor
Sounds like you need to adjust the linkage, very common.
Complete Source for Factory Diagnostic and Repair Information!! ALLDATAdiy.com ALLDATAdiy.com provides more detailed diagrams and repair information than any paper manual. And ALLDATAdiy.com is never generic - all information is specific to your vehicle. Plus, you get factory Technical Service Bulletins and Recall information updated regularly! AudiWorld Discount only $19.95 for a subscription to ALLDATAdiy.com using code AWDISCOUNT |
#4 |
Thanks for the help guys. Yep, the linkage slipped. Took anout 2.5 hours to figure out repair. Could do it in the 30 minutes next time. Again, many thanks.
Bradster |
#5 |
You may want to replace the wiper transmission. I had this happen and it got progressively worse. There are DIY instructions out there if you search and you can get the part from ECS.
#6 |
1991 Audi 200My Garage Join Date: Mar 2011
Have the same problem on 91 20VTQW. I've been told that the wiper control unit may need to be replaced. The mechanical linkage appears fine and the wipers did not "slip", but it seems like due to sever weather and freezing, the control unit has "forgotten" its "home position". Worst case, if it keys off the motor, the motor may have an issue reporting its position to the control unit. Will keep thread informed once I confirm which fix works. As a workaround, I've been quickly tapping down on the wipe switch until they go down to a reasonable angle - takes two or three tries to get it just right.
#7 |
did you ever find a fix? Mine do the same thing
#8 |
same thing happend to me, i sprayed some WD40 on it. works like a charm now
#9 |
sorry i mean i popped the hood and sprayed some on and around the hinges
| Tags |
| 2004, a4, audi, location, place, resting, spot, stop, stopping, stops, windshied, windshield, wiper, wipers, wrong |
