Old 01-01-2011, 08:53 AM   #1
Redneck Truck
Redneck Truck's Avatar
Default Flushing brake system, bleeding master cylinder and ABS pump (w/ ESP)
When I disassembled my right rear caliper I lost a lot of fluid and I think air got into the master from the top. After a lot of bleeding with a pressure bleeder and by hand, but I've still got a spongy pedal. I'm aware of how to use VAG COM basic settings to bleed the ABS pump, but I'm not aware of any special procedures for the ESP, and I don't know how to bleed the master cylinder. Could anybody make/find me a brief writeup on the job?
2001 A6 4.2 Quattro 6-speed
2001 TT Quattro Roadster TDI
2005 Jetta Wagon TDI
2006 CBR1000RR
C5 tech, writeups, help blog.
Redneck Truck is offline   Reply With Quote
Old 01-01-2011, 09:03 AM   #2
Peter Badore
Did you bleed all the wheel cylinders or only the one that you disassembled?
Peter Badore is offline   Reply With Quote
Old 01-01-2011, 09:17 AM   #3
Redneck Truck
I pressure bled all four corners. My friend the tech also operated the abs pump in basic settings, but I don't think he went through the whole procedure, as I did it on my Golf last night and don't remember seeing him do some of the things.
2006 CBR1000RR
Old 01-01-2011, 09:35 AM   #4
Johann2.7t
ive bleed the brakes properly without operating the abs pump. Ive read its just to flush out the old fluid (ie if you didnt drain the whole system).
I think you need to bleed more.
Johann2.7t is offline   Reply With Quote
Old 01-01-2011, 09:39 AM   #5
Just Me
the abs pump is also the ESP pump - so its the same. Its very hard to get air into the ABS system, btu if you do, its also hard to get it out. According to Audi, you need over 27 psi (working from memory) - which i NEVER use.
Bleeding the master occurs automatically when you pressure bleed the wheels.
Now, a i recall you have a 6-speed. Did you also bleed the clutch?
G
glenahan@vee-eff-email*dot*net
Just Me is offline   Reply With Quote
Old 01-01-2011, 09:41 AM   #6
Just Me
Well, hen i ran the master dry ( don't ask and i won't tell) i had to use a combo method - manual bleeding with pressure simultaneously applied.
It took many, many passes to get the deep-down air out. And about 2 liters of fluid. Live and learn. Always have a full pressure bleeder tank!
G
Old 01-01-2011, 09:44 AM   #7
Redneck Truck
Clutch is fine. Reservoir was bone dry though so enough of the system was drained that it all needed bled. Additionally, I've heard it's a good idea to replace old fluid, to include the stuff in the abs. Anybody know the procedure?
2006 CBR1000RR
Old 01-01-2011, 11:25 AM   #8
Just Me
yes, procedure is in bentley. Normal pressure bleed procedure, except that you activate the abs pump with vag com for 10 seconds.
I don't know the code or sequence.
G
Old 01-01-2011, 07:33 PM   #9
Airbag
i just went through all this recently . had you r exact symptom , ran the system dry.. had a spongy pedal for a while after bleeeding teice .. after I went out on an icy day and let the abs do her thing the pedal is fine now .. i guess if it runs dry you can trap an air pocket .. on my second bleed a did get aditional small bubbles .. next time i will do the initial bleed with chaeap brake fluid and save my superblue for the last bleed .. lesson learned ..
Airbag is offline   Reply With Quote
Old 01-02-2011, 11:56 AM   #10
Just Me
snow day = God's vag-com?
18t, 1997, 98, a6, abs, activate, audi, auidi, bentley, bleed, brake, cylindar, cylinder, cylinderbrakes, forum, location, master, pump
