S8 - How to check power steering fluid and replace air filters
#22
Eh, you just made an assumption about micro flow and gross particulate filtration. Perhaps the K&N's are better at micro channel short length pathways where paper filters flow air through treacherous pathes instead? Same filtration max defect size but longer, more complex pathes. That would certainly slow flow and be less efficient.
#23
Thanks for the post guys. I just purchased my 07 S8 with 56,000 miles so this is a definite project this weekend. Pictures are priceless. Great help as always on this forum.
#24
I am straining to not go full-blown textile engineer on this topic. ha.
#25
Thanks for the write up, must get round to checking mine,
On the topic of filters to use the following might be of interest to read when you have 5
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
#26
I'll go ahead and apologize for calling you out as you are a much more senior member of the forum but I had to chime in that this is a very incorrect statement. There are many different design characteristics of material flow (through filters in this case), apart from size, that can provide the means to lower intake resistance and keep the same level of filtering.
So, you are saying that there are better filtering materials than those used in standard automotive filters. Let's see how feasible, economical and useful would be building a custom filter using one of those supreme materials.
By the way, if anybody wants to feel all possible gain from lowering intake resistance just take your filter out and try how much better your car goes (if you can feel or measure any difference).
#27
This was recently suggested in another forum here on AW, the idea being to measure 0-60 times.
#28
Ha! and yes, good point, let's not talk the price of said materials.
#29
Hi, Do the servo oil need to be changed? I read that the fluid should be a green fluid called green something. But i didnt see anything about how many Liters, do anyone know? And i saw a tip on how to suck it out.
I asked i while ago about a whining sound, and i now suspect it is the steering power, and when turning the steering wheel it feels a little halting.
Have anyone had this problem? and possible solutions
#30
Yes, your symptoms do sound like the steering/pump. Perhaps just tired. About all I can suggest to do is check fluid level, and with motor running turn the wheel hard from hard left to hard right and back several times. That can help get air out of the system if there is any. Less strain on the system if done with the front wheels are off the ground.
