Go Back   AudiWorld Forums > Audi Models > Audi S4 / RS4 > S4 (B8 Platform) Discussion
S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-present
Old 12-03-2010, 07:57 AM   #1
asm777
Account #: 191313
asm777's Avatar
Default Backup Camera Stopped Working and TPMS Recall?
A few days ago, my backup camera started flickering and then just stopped working altogether. Did a search on the forum and found a similar description of the problem for a Q7 (http://forums.audiworld.com/showthre...ht=rear+camera)
The backup camera would not activate at all in reverse for about a day and then it just started working again. Anyway, after I dropped my S4 off at the dealership this morning to have it checked out, was informed that there's a recall for the TPMS sensors. Don't have more details yet but will update after I get it back.
But still nothing for all the water pumps for those with 2010s, huh?
2011 S4 P+ Quartz Gray/Black
2010 Q5 P+ Quartz Gray/Black
**VCDS/VAG-COM available**
asm777 is offline   Reply With Quote
Old 12-03-2010, 08:46 AM   #2
LeadToRome
Account #: 114664
There are no sensors on the '11s, I don't know about the '10s.
LeadToRome is offline   Reply With Quote
Old 12-03-2010, 08:54 AM   #3
Zed 2.0
Account #: 19916
No sensors in the '10s, either. TPMS runs off the ABS sensors.
Zed 2.0 is offline   Reply With Quote
Old 12-03-2010, 09:16 AM   #4
asm777
Account #: 191313
asm777's Avatar
Sorry, I think SA may have said that there is a "TPMS recall for your car and we'll take care of it" and I misinterpreted that to mean "sensors". I guess I'll find out for sure when I get the car back.
Old 12-03-2010, 12:51 PM   #5
k1speederS4
Account #: 190785
k1speederS4's Avatar
I had the same thing happen. Mine started working again after a few days. I noticed that it didn't work when I started the car but after a while it starting working. Apparently it is a battery issue that if you have LEDs installed or your startup battery is not full then it has a problem for a minute. The latest updated fixed it turning off but it still flickers. My Q5 does it too though
k1speederS4 is offline   Reply With Quote
Old 12-04-2010, 01:16 PM   #6
asm777
Account #: 191313
asm777's Avatar
Latest update for? Mine happened when I arrived home after work and was backing into the garage so not at startup.
As for the "TPMS recall", apparently it was a software update for the MMI.
Old 03-01-2011, 05:19 PM   #7
surgeon
Account #: 182833
Any further issues with your back up camera? I just had the flickering of my back up camera today - first time - only 770 km on it...
May I ask did you get the cable replaced as was the solution on the forum to which you referred? And if so/not, what's your situation now?
Cheers.
surgeon is offline   Reply With Quote
Old 03-02-2011, 04:59 AM   #8
bimmers2
Account #: 159326
mine started working after i restart engine.... happened 2 times on my 15K mile 2010 s4
bimmers2 is offline   Reply With Quote
Old 03-02-2011, 09:10 AM   #9
asm777
Account #: 191313
asm777's Avatar
Cheers.
First time I took the car in, the issue had gone away and the dealer didnt find any fault codes.
The next time, there were fault codes and I had recorded a video of the backup camera not working.
Ended up getting the rear view camera module replaced (not sure if that included the wiring harness).
I actually had to go in a third time to re-calibrate the rear view camera. Only knew it wasn't properly calibrated because of a VCDS fault. Turned out the dealer's calibration equipment was faulty and they had to borrow the equipment from another dealership!
Anyway, hope that helps and that you get yours repaired/replaced too!
Old 03-02-2011, 09:52 AM   #10
RedMagma2011S4
Account #: 208253
RedMagma2011S4's Avatar
Does that mean I can buy a set of aftermarket wheels and winter tires and TPMS will keep working after the swap?
No, honey, you can't take my car.
RedMagma2011S4 is offline   Reply With Quote
audi, backup, camera, car, longer, recall, reset, reverse, s4, starting, stop, stopped, tires, tpms, winter, working
Forum Jump
