Go Back   AudiWorld Forums » Regional & ACNA Discussion » Philadelphia Discussion
Old 12-01-2010, 11:56 AM   #1
APTuning, LLC
Former Vendor
Default APTuning December Special- Winterize Your Ride For $59.95!!!
Click the image to open in full size.Click the image to open in full size.
There is nothing worse then having a problem in the winter, with low temperatures and possible snow & ice it can make even minor car troubles unbearable and unsafe. So let APTuning give your vehicle a thorough check and get it ready for the upcoming cold months.
Winterize Service includes the following:
*Check, flush and fill washer fluid with sub-zero mix.
*Check and adjust wiper blades and arms.
*Rotate tires or install snow set if applicable.
*Properly inflate all tires to spec.
*Check charging system and battery.
*Check and clean battery terminals.
*Check coolant level and condition.
*Check oil level and condition.
*Check and lube key locks and cylinders.
*Check and lube all hinges.
*Check heater and defroster systems.
*Check and clean door seals.
*Check all mechanical and hydraulic brake components.
*Check all suspension components.
*Check lights for function and light output.
*VCDS(Vag-Com) scan of all modules for faults.
APTuning, LLC is offline   Reply With Quote
vag, winterize
