AAH vs AFC engine code
Old 11-15-2010, 02:47 PM
hitler's beeyatch's Avatar
Default AAH vs AFC engine code
Hi
I have a '95 90 Quattro that is needing an engine. I have verified that it is the AFC engine code. I am looking at a 2.8 out of a '97 A4, but don't know if it's compatible and even what the difference is between the two codes???
Any info would be greatly appreciated.
Thanks in advance!
Old 11-16-2010, 05:20 AM
Lago Blue's Avatar
Default Re: AAH vs AFC engine code...
You will want to read through this entire site eventually:
<b><u>12v.org</u></b>
It will give you the technical differences; &
here is a link to where one choice is "Identification"
http://www.12v.org/engine/index.php
Old 11-16-2010, 03:22 PM
Thanks, Lago. I've been out of the VW/Audi scene since the early 90's. Looks like I've got a lot of reading to do. Thanks again.
Old 11-16-2010, 03:51 PM
maineman's Avatar
I believe the 97 would be obd2 which I believe would be a problem.
Old 11-17-2010, 06:03 PM
CRAZY_RUSSIAN's Avatar
as long as he changes the sensors and the flywheel, he should be fine.
Old 11-18-2010, 07:09 PM
cuatrokoop's Avatar
The A4 will have an AFC, exact same engine, if the A4 is a manual, it even uses the same transmission. Use all of your sensors and harnessing, the A4 will be OBDII, your car is likely OBDI (switch was in 1996 I believe).
The AAH is the older 2.8L engine, first used in the 1992 100, last used in the 1994 100 and 90. It MAY have snuck in to some '95 cars.
Old 07-05-2011, 01:36 PM
nickstrub1@yahoo.com's Avatar
i want to know if a 2.8 5v would fit into a 93 audi 90 n e suggestions?
Old 07-05-2011, 05:29 PM
fit, yes, plug and play, NOT A CHANCE IN HELL! why would you anyway?
vkamnyev
A4 (B9 Platform) Discussion
22
04-07-2021 09:11 AM
Davemay123
1.8T Discussion
02-06-2017 08:47 AM
Audi2.8L
03-08-2010 07:56 PM
rmonster
05-08-2009 12:53 AM
Ed@mtl
Canadian Discussion
02-07-2003 05:11 AM
Quick Reply: AAH vs AFC engine code
