NUMBERS, NUMBERS, and more NUMBERS for STASIS EXHAUST AND ECU UPGRADE
YES I AM YELLING!!!!!!
Just thought I would share some info. Not to sound like a D!CK, say what you will but i'm happy as hell my results. Just waiting for someone to leave in my dust.
Back Ground info:
Run #1 and #3 were in 4th gear
Run #1 is STOCK and Run #3 is Stasis Exhaust and ECU upgrade
Run #1 : 54 F, 29.78 in-Hg, Humidity 53%, and SAE 0.96 on 2/6/2010
Run# 3 : 61 F, 29.69 in-Hg, Humidity 55%, and SAE 0.98 on 10/23/2010
Run #1: AWHP = 287.12, AWTQ = 290.42
Run #3: AWHP = 327.38, AWTQ = 311.11
Delta AWHP = 40.3, AWTQ = 20.7
Run #2 and #5 were in 3rd gear
Run #2 is STOCK and Run #5 is Stasis Exhaust and ECU upgrade
Run #2 : 54 F, 29.78 in-Hg, Humidity 53%, and SAE 0.96 on 2/6/2010
Run# 5 : 61 F, 29.69 in-Hg, Humidity 55%, and SAE 0.98 on 10/23/2010
Run #2: AWHP = 306.60, AWTQ = 295.76
Run #5: AWHP = 353.13, AWTQ = 312.07
Delta AWHP = 46.5, AWTQ = 16.3
Dyno is a Dynojet Model 424xLC2
This was done at Carburetor Connection in Kirkland, WA
Thanks Guys!!!
Disclaimer: I boned it by not putting my car in Dynamic mode, not sure how much of a difference that would make, but please chime in about it. They said the would work with me if i find out it does.
NOW FOR THE GRAPHS!!!!
Back Ground info:
Thanks Guys!!!
Quick question...does your exhaust drone between 1900-2500 rpm? Mine does and it's annoying me at highway cruising speed. Thanks for the dyno numbers. Got mines installed last week.
Great stu. Don't worry about dynamic. Max power is Max power. Dynamic maybe would add 1hp. Awe tested this for me.
