#1 |
#2 |
Oh, I forgot to mention that I've also done all-red tail lights:
![]() And installed the gauge faces that I was working on a few topics down: ![]() This car is mostly about messing around and experimenting, since it was cheap and I don't really have an emotional attachment to it. Although I did have to drag it over three winding mountain passes to get it home... Other plans include the one-piece front turn signal mod and quad-round headlights, similar to this, although I'll probably go without the crappy plastic headlight covers, which just never seem to look right: ![]() Performance-wise, I picked up an Intended Acceleration ECU with a stiffer wastegate spring. I'm hoping for around 200hp. I'm doing new engine gaskets, ARP studs, all the usual stuff. Nothing fancy, just a fun project that I can try a few ideas on, really. -Rog |
#3 |
I finally wrestled the old engine out of the 4000...
![]() Unfortunately I'm a driveway mechanic at the moment, so I didn't have the option of removing the front sheet metal and backing the engine straight out, nor do I have a good way of dropping it out the bottom. So out the top it had to come. Some tips if you have to do the same: 1. Remove the hood, obviously. 2. Remove as many of the easy pieces as you can, such as the intake manifold, radiator, airbox and fuel distributor, et cetera. Trust me, it's much easier to do it at the beginning so you can get to every bolt instead of trying to pry things around to do it when the engine is dangling half in the air and you realize you're hung up. 3. You have to remove the "snub mount", which is the bracket on the front of the engine that has a big rubber piece on it, along with the piece right behind the bumper that holds it down. This piece is to keep the engine from tipping backward when it's under load, so definitely put it back on when you're done. 4. It'll help a lot if you can do the core support mod, as if you were going to take it out the front, but you could possibly do it without any cutting at all. I ended up taking just a small section out of the top part. 5. The most important part is to figure out a good combination of taking off the downpipe, exhaust manifold, and/or the passenger side motor mount. It's kind of a puzzle box in there. Any one piece can be taken off without any of the others, but unfortunately they're all tangled up together. If you can get to one particular bolt on the bottom side of the downpipe-to-manifold flange then you'll have it made. That's a tough one though and I ended up rounding it off. What I eventually had to do is remove the passenger side motor mount completely and then I unbolted the exhaust manifold. Then it's not too bad to lift on out. Don't forget to remove the oil filter if you do it that way. Getting the new engine in should be fun, but I'll figure that out when the time comes. Also, if you have to do any valve work, I highly recommend getting this type of spring compressor: ![]() That thing is slick. I found them on eBay for under $100, most other places are $200 or so. Always shop around! -Rog |
#4 |
I've also been working on getting these stupid wheel studs off that one of the previous owners installed:
![]() I really hate whoever that person was right now. First of all, I thought that the car didn't come with a tool to remove the lug nuts so I've been trying all sorts of different things because they're sort of a security style, basically an oddly-shaped hex key. But finally when I went to dig into the glove box to remove the old ECU and AC evaporator I found the tool in there. So that's the easy part. The next stupid thing is that the studs aren't metric, so they're slightly too big and are really tight. And someone stupid enough to do this obviously wouldn't put antiseize on the threads. So in the three I've managed to remove my allen key is already getting twisted... Plus the fact that I only have metric allen wrenches doesn't help. The threads in the hub are a little messed up because of the incorrect studs, but so far it seems to be salvageable. (EDIT: They weren't, and I ended up replacing all the hubs.) I guess I'm not surprised, I mean the car came with one of those silly Walmart universal shift ***** that never stay on, so of course a junky set of wheel studs and lugs would find their way on there. Also observe that they are conical seat lugs, not the proper ball seat ones. Just stupid. Oh, and of course I should've done at least the front wheels before I took the engine out, as putting the car in gear is useless now and having someone step on the brakes without any power assist doesn't quite hold it well enough. But if this is the worst thing from here on out I'll be happy. ![]() Probably not though. -Rog Last edited by Rogviler; 08-04-2012 at 06:23 PM. |
#5 |
I'm going to write a concise "shopping list" of what to make sure you snag when you pull the donor engine if you happen to do the same swap from a junkyard pull like I'm doing. I wish I'd had one, since I pretty much had free rein to pull whatever I needed for free after the cost of the engine and neglected to get the ignition coil and fuel pump relay (which aren't mentioned in the most popular swap guide so I assumed you used the stock 4kq stuff), so now I have to get those separately.
I'm also going to write down some clear instructions regarding the wiring, since all of the information is scattered around and some of it's pretty messy. And depending on when your harness was made, some of the wiring info is completely wrong. If you're like me you want exact diagrams and clear descriptions, not "if I remember right" and "I think this wire is for..." I'm currently working on the wiring part, trying to get some clarification from the community and tracing wires out with the ole multimeter and a wiring diagram. So if you're interested in those bits of info, be sure you follow this thread. I really want to cater to people who are nervous about this type of swap or don't have a degree in electrical engineering or auto mechanics like everyone else who does it seems to. I know from experience that it's no fun to feel lost. Please don't be afraid to ask questions! Especially basic ones, because that's where something like this always starts. If I don't know the answer then we'll learn together. -Rog Last edited by Rogviler; 10-05-2010 at 07:43 PM. |
#6 |
A little update on the fake Sport Quattro hood...
I finally got the front "three grilles" panel figured out, so I started tacking it to the hood today. ![]() A gold star to whoever can name what the grille cutouts came from... For some reason the picture made it look like the angle of that piece is really perpendicular, but it's actually less than 45 degrees, more or less what the real thing is. I realize that the three grilles are positioned a little differently, aren't quite as tall, a different shape, et cetera, but so far I've spent $40 on this project, which will give much of the functionality and the looks, versus $3000 for a nice replica that would fit a 4000, so do the math if you want. I'll wait. ![]() Also, the grille piece isn't going to be as tall as it looks. The center part of the hood is cut along the sides and front, and is more or less a flap at the moment, which I propped up to do the welding. It'll get trimmed and sit a lot farther down. It's just easier to trim excess than try to scab on a piece when I come up short. I hope this was the hardest part, but I'm pretty well dreading the louvers over the turbo. I suspect those are going to be a lot of fun. I'm considering not doing them or maybe doing something different, but since the car is going to have a turbocharger, I might as well for functionality. I know those need all the cooling they can get. Overall, I accept that it's a custom piece and won't look exactly the same. Call it what Audi would've done if they'd offered a cheaper option for a 4000 turbo (if they made one) or call it me not having the kind of job that affords me thousands of dollars in disposable income. Either way I think it's turning out even better than I hoped. -Rog Last edited by Rogviler; 10-08-2010 at 09:32 PM. |
#7 |
Got the center part of the hood tacked to the grille panel. It was kind of a compromise between having it look proportional to the original and having the same rise as the original, just because the grille openings are about 3/4" shorter. I decided to go with the same rise, which means there's more distance between the top of the grilles and the top of the hood, but I wanted the extra space for airflow.
Pics: ![]() Showing the angle: ![]() I think it's coming along well. I still need to fill in the sides, but at least it's solid again. -Rog |
#8 |
Some of my visual notes for the SQ hood for anyone interested...
I believe this is the original: ![]() Note how far back the three grilles are, and that there is a little detail piece on each side that creates a sort of scoop look. I might do this if I can come up with a good way to do it. Probably two little triangles cut from some square stock would do it... This is a less accurate copy: ![]() Note that the grilles are set back the same amount, but there isn't any of the detail bits, it's just smooth. Finally, an even less accurate copy: ![]() I actually like this one the best. Note how the grilles are right at the edge of the hood. I was going to do this, but realized that there was a bunch of reinforcement in the way underneath, so I had to set it back a ways. I still had to trim off some of the extra metal, but with all the extra reinforcement I added I wouldn't be surprised if it's actually stronger than it was. Anyway, the fact that there is so much variation out there makes me a little more comfortable with making my own. Haters gonna hate of course, but I'm having fun doing it and that's all that matters to me. -Rog |
#9 |
Awesome build thread. I'm keeping an eye out for updates, as I have an 87 CGT sitting in my garage I bought with the best intentions, but haven't gotten a chance to work on yet, and I like that you're pretty thorough with your posts.
Also, good to see more 4k enthusia in CO! Are you in Denver? Keep it up man! |
#10 |
Thanks! If even one person gains something from my experience it's worth it...
I'm actually near Grand Junction. Wesside, yo! I don't think I've ever met another Audi enthusiast around here, except for one guy who stopped me in the mall parking lot to chat about my car and how, among other things, I should put a W8 in it. ![]() Might as well do an update... I found some steel tubing from a broken floor fan that's the right radius to cut in half to fill in the sloped sides where I cut the center of the hood (the flap). I thought about trying to roll the existing bevels up more to meet the flappy part, but I know my limitations and I don't want it to look like crap if I can help it. ![]() So I welded the tubing halves on, which worked great, but they were short so now I have about a foot left where there's just a little sliver of space to fill in. That's where I've stopped because it's been frustrating to try to weld a little strip in there without the hood flap moving around and warping. I'm still mulling a good way to do this. In the meantime, I've discovered some stuff called Plasti Dip that I'm playing around with. It's basically a rubbery plastic spray-on coating that normally you coat tool handles with. It seems a lot of people use it on their bumpers and even wheels and interior bits. The nice part about it is that if it ever gets damaged or you don't want it anymore you can just peel it right off. So I'm hoping this will be a good way to take care of some of the aging trim and plastic on this car while staying within a reasonable budget. If I'm ambitious I might paint the whole car with it. ![]() Anyway, you can get it in black at most hardware stores like Home Depot. I'm trying to find some of the red to see if it's close to the Tornado Red on my '84... -Rog Last edited by Rogviler; 10-14-2010 at 10:58 AM. |
| Tags |
| 1985, 4000, 4000s, audi, clutch, coupe, front, grill, headlight, hoods, plastic, quattro, replace, shop, sport, swap, turbo |
