Super Easy Front US Orange Reflector/Light Fix for Brilliant Black D3's
Super easy US front bumper light delete for D3 A8's/S8's
Go to your local sign or crafts store and buy some glossy black vinyl adhesive sheets (or tape if wide enough). Cut out pattern about 1/4" inch larger than the edges of the front orange bumper light/reflector required on US spec D3's. Center, adhere, and use a soft rubber spatula or putty knife to insert the extra trim into the crease between the surrounding bumper and the reflector.
This is indistinguishable form the stock Euro bumper trim piece unless you specifically point it out and even then the only difference is an extra vertical line where the covered reflector ends and the black plastic trim resumes.
Last edited by ModestW12; 08-31-2010 at 04:21 PM. Reason: Edited title for clarity
BTW, the pics above are of my actual car with the glossy black tape covering the reflectors.
I'll soon post some higher res close ups from my Canon DSLR.
The big advantage is is costs no more than $20 (minimum order at the shop I went to, $1 worth would have been enough), take about 5 minutes, and it's completely reversible (just peel it off).
I know I have an a8 and I love my car. And my friends are all envious and love it as well. But i Have to say I absolutely love you car and am completely jealous of that beast!
Thanks Brozee! But maybe you won't be so envious if I leave you with this analogy for my feelings about the W12:
I feel like the ostensibly super lucky guy who's married to a gorgeous, classy, ambitious and spectacular wife (the W12), all the while he must live secretly cursed because he's madly in love with her wild younger sister (a black ext./black alcantara int. D3 S8).
I did notice that the sign shop I went to had lots of different rolls of adhesive vinyl sheets (looked like 40+ different colors from where I was standing). It's worth a try to see if they have a silver like the paint of your car. It would seem like those white and sliver paints would have a pretty good shot at a match.
I'm actually in need of some silver touchup paint, as my left headlight washer has a large circle of paint missing where a rock chipped it and the rest peeled away. You can see it in my sig if you look close enough. Not only that but also I am experiencing my clear coat is chipping around the audi rings on the trunk. Anyone have a fix for this?
