| Q7 Discussion Discussion forum for the Audi Q7 SUV
Sponsored by: Audi ![]()
#1 | ||
Paul 2011 Q7 TDI Prestige 2007 Q7 4.2 Premium-traded 2011 Subaru Outback 2.5i Limited 1997 MB S500-gone 1995 Porsche 993-gone but not forgotten
#2 |
The warning light is only for pad thickness and has nothing to do with rotors. When the warning light comes on the amount of driving you have before changing the pads depends on how you drive. I wouldn't go more than a 1000 km and that's pushing it. Strict dealships will replace the pad immediately the light goes on./
There seems to be some dicrepencey between the EU and the US on rotors. As I undertand it US dealerships are "required" to change the rotors when the pads are changed, which seems insane to me as if more than doubles the cost. Here in the EU I have change the pads twice on one Q7 and never changed the rotors. The do have a lip and I assume the third pad change will also require a rotor change. |
#3 |
![]() Join Date: May 2006
Why bother machining the lips?
Wear is a mere 1mm per side total reduction of 2mm to replacement Disc/Rotor thickness 34mm Minimum Rotor thickness 32mm Its the same spec accross all models or rims size
Q5 related Link to Q5 Spreadsheet *Exterior pics* *Interiors* Q7 related Link to Q7 Spreadsheet *Exterior pics by color, model and rim size* *Interior pics* A4 S4 Spreadsheet Link to Q3 spreadsheet |
#4 |
Well, I'm right at the minimum thickness now. I bought the car with 36000 miles on the clock and I'm at 51000 now. I don't know if the car is on it's second set of rotors now but in any case I'm replacing the rotors with Frozen Rotors.
#5 | |
Here in portugal our 07/01 Q7 had its first rotor replace ment at 150,000 km - went through four sets of pads. Note that this was an Audi dealership and associated Audi shop. None of this "must replace rotors and pads at the same time" crap. None of this "oh noes! The rotors have worn by 2 mm - replace them noaw!". I think both the pads/rotor and the 2mm wear limit is trumped up rubbish designed to screw over the uninformed by turning a 450 Euro pad replacement into a 1200 Euro pad + rotor replacement. But that's just me.
#6 |
Its not just you... its me too. They are soft material to match pad wear but mine looked perfect at first pad replacement (despite wear) so they stayed. I will certainly monitor them really carefully. Slightest sign of a crack or pedal hop they're out of there but for now still probably the best rotors I have ever had!
Q5 related Link to Q5 Spreadsheet *Exterior pics* *Interiors* Q7 related Link to Q7 Spreadsheet *Exterior pics by color, model and rim size* *Interior pics* A4 S4 Spreadsheet Link to Q3 spreadsheet Last edited by Jusforfun; 08-25-2010 at 07:01 PM. |
| Tags |
| 2001, 2003, 2006, a4, a6, allroad, audi, brake, minimum, minimums, rotor, rotors, rs4, s4, thickness |
