Old 08-04-2010, 08:52 PM   #1
e292644
Account #: 185918
Default How to Replace Camshaft End Cap Seal
99' A6 C5 2.8L Camshaft end cap seal leaking small amount of oil everyday.
TC and valve cover gasket just done not to long ago, new vacuum line, jet suction pump and green valve.
I guess someone did not get the job done right.
My question is can I replace these two end cap seals(078 103 113E) without remove TC and camshaft?
Thanks!
e292644 is offline   Reply With Quote
Old 08-05-2010, 02:53 AM   #2
nickcarguy
Account #: 167356
If you are referring to the round black, small hockey puck looking caps at the rear of the engine, Yes. You can gently pry these cam plugs out with a small pick or screwdriver. Clean the area well. Press new caps back into place.
Should take all of ten minutes for both.
nickcarguy is offline   Reply With Quote
Old 08-05-2010, 06:04 AM   #3
e292644
Account #: 185918
Thanks for the tips.
Should I remove the holding block on top of it?
Old 08-05-2010, 06:22 AM   #4
nickcarguy
Account #: 167356
There was nothing holding mine in place. 2000 A6 Avant , 2.8 . Just a press fit.
Old 08-05-2010, 06:50 AM   #5
Redneck Truck
Account #: 171347
Redneck Truck's Avatar
rear cam caps unbolt, don't they?
2001 A6 4.2 Quattro 6-speed
2001 TT Quattro Roadster TDI
2005 Jetta Wagon TDI
2006 CBR1000RR
C5 tech, writeups, help blog.
Redneck Truck is offline   Reply With Quote
Old 08-05-2010, 07:43 AM   #6
e292644
Account #: 185918
I suppose some sealant need to apply before seating.
But if nickcarguy got it done by press it in without any leakage.
Then it should be ok.
Old 08-05-2010, 07:44 AM   #7
e292644
Account #: 185918
Thanks again!
Old 08-05-2010, 08:50 AM   #8
thejulex
Account #: 166957
NO! Do not apply any sealant. I once applied sealant to one and it popped out while boost leak testing @ 15psi a week later. Comes out that sealant prevented the rubber ribs from "digging in" the metal groove and lubricated otherwise pretty tacky rubber.
thejulex is offline   Reply With Quote
Old 08-05-2010, 09:45 AM   #9
e292644
Account #: 185918
Interesting, learn something new everyday.
Thanks for the tip!
Old 08-05-2010, 12:54 PM   #10
nfs1000f
Account #: 86512
Default Try this
http://forums.audiworld.com/showthread.php?p=23919460
2005.5 S4 - gone
2001 A6 2.8Q - gone
nfs1000f is offline   Reply With Quote
28, audi, cam, camshaft, cap, caps, end, rear, replace, replacement, replacing, seal, seals, shaft, tt
Forum Jump
