2006 A4 2.0 Camshaft Problem
Old 07-02-2010, 01:35 PM
catarina.farrow's Avatar
Default 2006 A4 2.0 Camshaft Problem
I have excessive wear of the cam lobe, in the intake camshaft, which limits maximum pump piston lift, causing fuel rail fluctuations. Leads to wear in base of high pressure fuel pump cam follower. I have been told this is an issue that Audi has acknowledged as a manufacturer's defect in early 2.0 A4s - any input would be appreciated.....
Old 07-03-2010, 03:59 PM
LBG
LBG's Avatar
Had the same issue. Replaced at no charge. Audi is aware of the problem.
They replaced the cam, fuel pump, & DV. They have replaced hundreds. It was a bad cam forge on the early 2006's. Don't take no for an answer.
Old 07-04-2010, 08:23 AM
makav3li's Avatar
sounds like ur cam follower died, that is a known problem in the b7 community, i just replaced mine yesterday and there was a noticable amount of wear on it. were told to replace the follower every 30k miles, i waited until 50k to change mine so it was due. If you have any sort of warranty, they should fix it
Old 07-04-2010, 11:58 AM
Old Dog's Avatar
I’m glad I read your post makav3li as this is one guy that didn’t know the cam followers were a problem in the B7’s . I am a first-time Audi owner for the past 2 ½ years with a 2007 A4 2.0TQ reading 41,000 miles approx. and an AW member since late Nov. 2009. This is the first time I can recall seeing this mentioned.
Would you be in a position to tell the Old Dog the early warning signs, the fix, and since I am still under warranty until Dec 2011 for the original 4-year warranty with an extended two-year warranty kicking in after that, is this something I can ask them to look at even if I am not suffering any problems that I know of?
Any guidance you, or other members, can provide would be greatly appreciated.
Forewarned is forearmed.
Thanks
2008 S-LINE
10-20-2010 07:40 AM
GarmischP
13
08-25-2010 08:43 AM
dfrost
Audi A3 / S3 / RS 3
08-11-2010 11:13 AM
audifan22
07-28-2009 06:20 PM
audiboi79
04-28-2009 02:31 PM
Quick Reply: 2006 A4 2.0 Camshaft Problem
