License plate holder removal?
Old 04-26-2010, 11:10 PM
nvofevery1's Avatar
Default License plate holder removal?
I moved to a state where the front plate is not needed. Can you take off the gray plastic thing that holds the license plate frame? Thanks.
Old 04-27-2010, 02:50 AM
bb vign's Avatar
Yes, the entire front US plate assembly can be removed with a few screws to reveal the Euro plate holder underneath. If not fitting a Euro front plate, get a filler panel to keep the look clean.
Old 04-27-2010, 05:05 AM
ChipB's Avatar
I replaced the front license plate holder with a filler plate - bought mine from madaudi.com
Old 04-27-2010, 09:45 AM
nvofevery1's Avatar
will take a look. thanks.
Old 04-27-2010, 03:28 PM
SoonerDPT's Avatar
Dealer told me that whole plastic piece screws out and you can replace it. He said $100-200 to get the one w/out lic plate bracket.
Old 05-08-2011, 06:06 PM
AgsWin's Avatar
Is there a difference between the license plate holder for the S5, A5 and A5 S-Line or is it all the same dull grey piece?
Old 05-08-2011, 08:21 PM
UmIsThisThingOn's Avatar
You'll need a Torx driver. I think it's size 20 or 25.
Can be had for less.
http://www.ecstuning.com/Audi-B8_A5-...r/Body/Grille/
Nope - same one except for the color to match the grill.
Old 05-08-2011, 08:49 PM
questionlp's Avatar
Don't forget to remove the license plate before trying to remove the holder, as there is a Torx screw that is covered the plate when installed. Other than that, it took me less than 5 minutes to remove the holder, clean the grille and install the filler.
Old 05-09-2011, 04:00 AM
Huey52's Avatar
I went with the Piano Black (shiny) plate filler myself. Nice contrast with Ice Silver. It was cheaper than the matte gray one to boot. ECS Tuning as well.
Old 02-04-2013, 07:01 AM
rbudiman's Avatar
any of you guys know how to remove the license plate bracket on the 2013 RS5 model? I heard its just 2 Torx screws that are holding the bracket to the grill but not quite sure. Any info on this?
Quick Reply: License plate holder removal?
