Brake caliper torque spec needed
Old 03-25-2010, 06:11 AM
K6XT's Avatar
Default Brake caliper torque spec needed
Hello
What are the torque specs for the front calipers? All 6 bolts:
2 bolts that attach caliper to wheel hub, take 21mm 13/16 wrench
4 bolts that screw caliper halves together, take hex key.
And, should I put a dab of loctite on some or all? (Didn't have any when taken apart.)
Thanks Art
2004 allroad 2.7T
Old 03-26-2010, 06:57 PM
indoor's Avatar
my car is 2001 and has hp2 calipers...what type of calipers do you have?(2 brake pads per wheel or 4 pads)
Old 03-26-2010, 07:15 PM
K6XT's Avatar
Old 03-26-2010, 08:14 PM
indoor's Avatar
'2 bolts that attach caliper to wheel hub, take 21mm 13/16 wrench' - 200 Nm or 148 ft-lb
the other bolts you are talking about I assume it's the 'brake caliper to pad carrier'(in the service manual)- that would be 25 Nm or 18 ft-lb
Old 03-29-2010, 05:46 AM
K6XT's Avatar
Thanks! My calipers come apart into two pieces by removing four hex head bolts. Lacking a service manual I couldn't connect my "two pieces" with "pad carrier". What I did is use the generic torque spec (google bolt torque spec) for that size bolt which is about 60 lb. They had a lot more than 20 lb on them at disassembly.
Edit: Torx scres not hex screws.
sudsaver
Brakes Discussion
12-12-2017 09:00 AM
am_ver
09-21-2009 10:02 PM
RC
A4 (B7 Platform) Discussion
09-06-2009 06:06 AM
blackfnTTruck
TT (Mk1) Discussion
13
11-17-2007 08:09 AM
CraigB
02-06-2000 08:02 PM
Quick Reply: Brake caliper torque spec needed
