Go Back   AudiWorld Forums > Audi Models > Audi S4 / RS4 > S4 / RS4 (B5 Platform) Discussion
Old 03-11-2010, 07:16 PM   #1
juschillins4
Account #: 176584
Default Lower Radiator Hose Removal!?!?
Im trying To Drain my coolant and as im sure u guys already kno the lower radiator Hose is not moving. How fragile is this thing? i dont wanna Break anything. Can i wiggle it off with Chanel locks and kinda twist it? any advice would be appreciated. thanx.
juschillins4 is offline   Reply With Quote
Old 03-11-2010, 08:11 PM   #2
Timtheguru
Account #: 146230
I would not use channel locks.
Mine wasn't fragile, just put on some gloves to give you a better grip and twist, up down left right and pull it out.. it can take a few minutes to free it up, the O ring on it is very tight. Putting it back in is a bitch too.. Don't forget to pull out the retainer clip and be careful putting it back in too.
Signature line: - - - 2001.5 Audi S4 2.7T 6Speed Full time AWD Quattro Sedan (Black beauty...AKA Batman)... what other redundant info can I provide - - -
Timtheguru is offline   Reply With Quote
Old 03-12-2010, 04:13 PM   #3
Faulk
Account #: 178962
Did you take the retainer clip out? After pulling that clip, a good strong tug straight back should disconnect it.
B5 S4 6MT, B7 S4 Avant 6MT
Faulk is offline   Reply With Quote
Old 03-12-2010, 05:47 PM   #4
juschillins4
Account #: 176584
Default clip is out
im just nervous about messing the sensor up if i pull to hard & far. when it stops raining im gonna give it another try. Is the sensor locked in real tight or do i risk popping it out when removing the hose??
Old 03-15-2010, 05:22 AM   #5
Faulk
Account #: 178962
I would take the sensor out before you start yanking on that lower radiator hose. It's a little bit of a pain in the butt to get out but just be gentle with it. There is a little plastic clip that you have to pull GENTLY off in order to get the sensor out. FYI, I would order a new plastic clip (or 2) while its raining. They are like $0.57 from JHM (I think). I broke mine taking it off and bought two extras just in case my meaty hands broke it again. Also, make sure you grab the o-ring when you take the sensor out. You don't want to lose that.
Old 03-15-2010, 07:10 AM   #6
bingS4
Account #: 113875
Don't twist it. There's a tab in there that makes it come off straight. Get a very broad screwdriver if you must and pry at it very tenderly, followed by lots of pulling with your hands and swearing and grunting. Yes, it's a pain. Yes, it will finally give up and come off.
bingS4 is offline   Reply With Quote
Old 03-16-2010, 04:14 PM   #7
juschillins4
Account #: 176584
Default Finished!
so i just Finished flushing my coolant and replacing the expansion tank/hose.Heat Works great. I ended up getting the lower radiator Hose off with a big flat head. It worked great , Popped right Off. Just Wanted to say thanks For The Help offered by you guys. I really appreciate it!!!
Old 01-07-2013, 02:12 PM   #8
o_a_ravi
Account #: 157893
Default Question about Lower Radiator Hose replacement
Just a noob question. To get to the lower radiator hose for replacement., do we need to remove the bumper and the front end to the service position ?
Or can it be accessed from the top/bottom without moving the carrier ? I am due for a new hose and wanted to know if this could be done easily.
o_a_ravi is offline   Reply With Quote
Old 01-07-2013, 03:16 PM   #9
Bill S4-01
Account #: 206214
Send a message via ICQ to Bill S4-01
Good luck if you can get if off without removing the bumper. I could not.
But my alternator crapped out on me around the same time as I was planning to change my hoses so I had to remove everything to get that out and replaced all the hoses I could see just in case.
Getting to that is next to impossible, I wish you luck.
Having said that, the front end isn't so hard to get off, it's just a "pain in the %%" and the way I look at it is, it's good practice for the next time you have to take it off.
Timeing belts, alternator, cam seals... long list of why we all need the practice
Bill S4-01 is offline   Reply With Quote
1999, 2003, 42, a4, a6, a8, audi, augi, bottom, diy, hose, lower, radiator, removal, s4, tt
Forum Jump
