Code P0421 was NOT catalytic converter
Old 02-24-2010, 10:54 AM
dpeverhart's Avatar
Default Code P0421 was NOT catalytic converter
I have a 2000 A4 with the 2.8 V6 and 139k. I recently had the check engine light come on and found it was code P0421. Most people told me it was the cats. I took it to a very reputable German car mechanic who said he's seen this in these Audi's and he felt that it was a faulty code, that the ECU parameters were too stringent.
Based on that info, I took it in to Audi and had them flash the ECU. That was about 1k miles ago and I haven't had the light come back on.
Old 02-24-2010, 11:03 AM
Tech Guru
4Driver4's Avatar
Common issue and fix. There is a TSB on this. Lucky your tech was sharp enough to dig it up.
Old 02-24-2010, 11:06 AM
dpeverhart's Avatar
There was a TSB? Does that mean I shouldn't have paid for it? They charged me $189 plus another $50 to remove the radio to get the radio code.
Old 02-24-2010, 01:47 PM
Tech Guru
4Driver4's Avatar
No. Audi service sucks.
They issue a TSB instead of a recall so they can decide who pays and who doesn't. Unless you are the original owner and the car has been serviced at Audi, forget it.
BTDT with the local dealer and Audi of America.
Their contention: car is out of warranty.
My contention: warranty period not applicable since nothing is broken; car is functioning as designed. Design flaw should be corrected at Audi expense.
Old 03-10-2010, 01:48 PM
jbracefan1977's Avatar
Code P0421 was NOT catalytic converter : I have a 2000 A4 with the 2.8 V6 and 139k. I recently had the check engine light come on and found it was code P0421. Most people told me it was the cats. I took it to a very reputable German car mechanic who said he's seen this in these Audi's and he felt that it was a faulty code, that the ECU parameters were too stringent.
That sucks that they charged you
Old 10-06-2014, 08:29 AM
rpmccas's Avatar
I'm having that problem with my A4 right now. I just contacted the dealer and they told me they are no longer doing the flash. Is there any way to take care of it myself? I'm going to try the spark plug defouler trick to see if that works. The dealer wanted to just replace the cats. I guess there wasn't enough money for them in just resetting the parameters.
Old 10-07-2014, 11:30 AM
Prospeeder's Avatar
Spark plug defouler trick does work. But you have to grind out the inside of one of the foulers to make room for the end of the o2 sensor. Alittle tedious with a dremel but so far has worked on the couple cars iv done it to. Seems some 30v 2.8 cars 98-00 Seem to have the issue.
officer120
Q5/SQ5 MKI (8R) Discussion
06-22-2018 10:19 AM
nbvolks
02-11-2008 06:03 AM
dahlem4
12-04-2004 08:21 AM
?PROXUS?
01-30-2004 06:23 PM
Marian (1.9tdi)
12-12-2003 10:45 AM
Quick Reply: Code P0421 was NOT catalytic converter
