| A8 / S8 (D3 Platform) Discussion Discussion forum for the D3 Audi A8 produced from 2003-2010 and Audi S8 produced from 2006-2010 |
#81 | ||
2005 Audi A8Join Date: Nov 2010
#82 |
Anyone have the actual OEM part numbers and sizes for the front and rear pads and rotors?
I've been to several sites all saying oem with different rotor diameters, etc. |
#83 | |
#84 | |
Senior Member
If a site is still confused, I move on. Not interested in hassles of returning parts if wrong, especially heavy ones like rotors.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly VAG COM lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; uprated fogs; other VAG COM tweaking to suit. Current #2: C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi On order: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery approx. 7/2013 Prior (each modded): '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
#85 |
Senior Member
you don't need a car charger. At least I haven't. But if your laptop is old like my PC dinosaur that got replaced by a Mac but is still needed to run VAG COM S/W, you may need a charger for that! ... it takes a while.
#86 |
AudiUSAParts.com-call them they will take your VIN and give you the corect PN/s for both front rear brakes/rotors.
#87 |
Do I have to run the Vag com twice when doing the left and rear pads/rotors?
I ran it once and replaced the drivers side rotors and pads no problem. Went to the pass side and took apart the calipers, but can not get the rotor off at all. Im not sure if it's rusted on or what? I've used WD40 and a soft mallet hammer to see if I could break it loose but this thing isnt budging at all. The drivers side was simple and came right off with no force at all. Do I need to rerun the Vag setting to release parking brake again for the pass side rear? |
#88 | |
I have had to use a torch to heat the rotor where it contacts the hub, After a minute, Beat the rotor off with a 10# sledge hammer. Popped it right off. |
#89 |
2007 Audi A8LMy Garage Join Date: Feb 2009
I'm using a 12 year old Thinkpad with a battery that doesn't really hold a charge, but I have an outlet close to the driver's door, so at least it works to run VAG-COM. Not likely to see a Mac version of the software anytime soon, so perhaps I can jump to a tablet version (when it comes out and if it has full functionality).
#90 |
Yes, I literally had to beat the rotor silly and it finally broke free. The rears were a piece of cake. The fronts a PITA b/c of the extra bolts that needed to be removed and replacing the caliper clip.
I ran through the vagcom settings per instructions and I still have the annoying brake pad warning icon. I've hooked up the new sensors and pressed the brake pedal a few times, even drove around the block and it's still there. Is there something else I need to do to clear the code? I tried clearing codes via vagcom but it's still there. |
| Tags |
| a8l, brake, brakes, break, buy, c5, front, in, irotor, pads, replace, rotor, rotors, rs6, s8 |
