| A8 / S8 (D3 Platform) Discussion Discussion forum for the D3 Audi A8 produced from 2003-2010 and Audi S8 produced from 2006-2010 |
#11 | ||
Senior Member
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly VAG COM lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; uprated fogs; other VAG COM tweaking to suit. Current #2: C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi On order: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery approx. 7/2013 Prior (each modded): '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
#12 |
I used Autoanything.com. I have also ordered parts from Amazon.com in the past so try at least both of these. Rotors are heavy so go with one that offers free shipping. My rotors for my Ford Excursion weighed 60 lbs and Amazon paid the shipping!
Thanks, NOW: 2007 S8 Daytona Grey Metallic Effect, Silver/Black seats, Black Alcantera, Carbon Fiber, Rear Dual HVAC, VAG COM Lowered 1", 20X9's, Michelin Pilot Super Sport 275/35ZR20's, K&N Filters, K40 Calibre with Laser Jamming, Kimber 0.45 APC. Winter Pkg: DRAG 19X8's (black) with Bridgstone Blizzak LM-22's 255/40R19 NEW: 1965 Impala SS, 350, Powerglide, cruiser....for now. PAST: 2005 A8L, Oyster Gray Metallic, Winter Pkg, Sport Pkg, Lowered by VAG COM, 285/35R19 Bridgestone RE-11's ,
#13 |
Senior Member
Looked at OEM pad set I have and see it is stamped as sourcing from Pagid. A Euro supplier. Have seen a lot of pads off newer Audi's from them and from Jurid as another one. If you want OEM equivalent you could search on either brand name and get a variety of hits; just did and better prices are similar to EBC. Likely can also get Audi OEM via ecs tuning on line.
#14 |
2004 Audi A8Join Date: Mar 2010
I had a custom set of Drilled/Slotted w/Black Hubs done at Adams Rotors and and went EBC Reds. Adam is comitted to Audizine only and will not advertise on any other Forum, but I stand by his Craftmanship as well the Audizine Community. Had my car in for Service and Audi Tech complimented the Brake Job. Best of luck. Laters,
williebone |
#15 |
2004 Audi A8My Garage Join Date: May 2005
Your write up on your F & R brake mods are excellent.
I am in the process of changing my front and rear pads. Thought about the rotors too since I'm in there but I think I can get some more life out of them. All 4 rotors are slightly lipped, inside and outside. Of course dealer said replace pads and rotors, they didn't even measure rotors... You think the OEM rotors are good for 100K miles? Or at least another 25K? My wife drives the car and is fairly tame with the car. Car is @ 58K miles now. Thank for your expert advice! |
#16 | |
FWIW, I've raced two seasons now, on stock rotors with my EBC pads up front and they performed well. The yellows dust as much as stock too.
#17 | |
2007 Audi A8My Garage Join Date: Jan 2010
I would go aftermarket pads too. Just me though.
2007 A8L 6.0L W12 Fully loaded every option Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control. 2005 A8 4.2L w/ all packages. Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, limo tint, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control. Popular Topics & Help for Noobies: Oil Change Procedure Disable TPMS System AMI Installation AMI Update (Phone not pairing) Remote Window Control Enable Hidden Menu & Enable Battery Meter Fog Light Replacement City Light Bulb Replacement Door, Trunk, & Glove Box LED Change Cabin Air Filter Change Maintenance & Common Problems |
#18 | |
I did end up installing EBC redstuff. I bought a caliper to measure rotor thickness and decide what to do after that. Measured it to 31.5 - 32mm. Min is 31mm. Last edited by cclcal; 10-21-2011 at 04:47 PM. Reason: new inof |
#19 |
My front rotors were replaced with the 2nd set of pad at about 140,000 miles. The rears are still onthe car with 145,000 on the rotors. I plan to replace the rear rotors and pads by the 150,000 mile mark.
#20 |
Senior Member
Don't know if you will quite see 100K on the fronts, but if you are at 58K now, that sounds like you likely have some more miles left. And as Mr. Bally reports, my Audi experience is the rears wear much more slowly than the fronts. Very front heavy car, most of braking action up front, etc. My most comparable experience is probably my C5 A6 with the 4.2. Weighs similarly to the D3 4.2. Had what were then big stock rotors (322mm), and it was pushing 100K miles when I changed them. D3 rotors are yet larger diameter giving it more "wear area" effectively. Net, to save $ you might decide to go one more pad cycle in front.
As you posted, best to check it with a mic/caliper. You can eyeball it just by looking at how deep that lip has gotten. My own experience is I have never lost an Audi rotor to cracking, and really not to warping either, just basic wear. As you wear them more, the heat sink capability is dropping so they are somewhat less effective against heat fade. But, these are brake systems literally built for Autobahn speeds. Finally, if I remember the various posts in the thread, you were going with EBC reds. I continue to like them for both feel and low dust. I am finding now over several pad changes and a couple of cars that they are harder on rotors, so figure that may cut your rotor life some. The pads last about as many miles as stock on the same vehicle from my own use so far.
| Tags |
| a8l, brake, brakes, break, buy, c5, front, in, irotor, pads, replace, rotor, rotors, rs6, s8 |
