Suspension problem not like most.....mine is stuck up!
*** FINAL UPDATE...the Allroad is lowww again, see page 2***
Well I have the N-111 purge valve stuck open code & it won't let me get out of level 4. At 1st it was intermittent, but now is constant. I put the suspension up so I could get out of my parking spot w/o having to shovel & now it stays there. I even tried driving 100mph to force it down, but it acts like it's gonna go down the level 3 & I have tried clearing it but just stays.
Do you think it is because of the cold weather & I should just wait it out or will I need to replace it, if so where can I get one besides the dealer & where is it at?
Oh & yeah the yellow man light is on, only cuz I keep it in manual mode but it will let me put it back into auto mode if I hold one of the up or down buttons
Comrpessor
Thanks
Adam
Arnott thanks for the info and thank you for building affordable replacement suspension parts for the Allroad!!!!! I plan on getting the Gen 2 bags as soon as 1 of mine goes & looks like I might need to get one of your compressors too
and my plot thickens......
My suspension light started blinking & I noticed the car itself is higher than I have ever seen it so I ran my vag-com & pulled these codes:
Control Module Part Number: 4Z7 907 553 BG
Component and/or Version: - 2C1A1 X031
Software Coding: 25500
Work Shop Code: WSC 20111
3 Faults Found:
01397 - Venting Solenoid for Level Control (N111)
31-10 - Open or Short to Ground - Intermittent
01400 - Suspension Level Control
08-10 - Control Limit Surpassed - Intermittent
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
3 Faults Found:
