Go Back   AudiWorld Forums > Audi Models > Other Audi > Audi 5000 / 200 / V8 Discussion
Old 02-07-2010, 07:46 AM   #1
prdbloke
Account #: 178235
Default V8 quattro stuck throttle
My 1991 V8 quattro 3.6 has been standing unused for several months because I have been in hospital. Now when I start it it races at maximum revs (around 7,000 rpm). Advice please? I have had this car for 14 years and will keep it for many years more if I can.
prdbloke is offline   Reply With Quote
Old 02-07-2010, 10:17 AM   #2
Jairek
Account #: 176150
Send a message via MSN to Jairek
did you check your bushing on the throttle cable Ive heard that this can be the culprit ?
Jairek is offline   Reply With Quote
Old 02-07-2010, 10:34 AM   #3
prdbloke
Account #: 178235
Whereabouts do I look?
Old 02-07-2010, 07:37 PM   #4
Jairek
Account #: 176150
it should be on the throttle body if you got a manual it would help i cant seem to find mine check on top of where the gas pedal pulls the cable out
Old 02-09-2010, 05:01 AM   #5
V8QinNJ
Account #: 114115
You can "force" the throddle back closed by pushing on a lever on the TB.
Then you can determine if the bearing (item 10) is siezed or the cable mounting area (large block with the rod connected to it) under the air filter housing just needs some PB Blaster and some movement to clear it up.
_________________
Scott
'90 V8 Quattro Papryus Metallic (SOLD)
'90 V8 Quattro Pearl Metallic
'90 V8 Quattro Crystal Silver Metallic
'90 V8 Quattro Pearl Metallic (Parts)
V8QinNJ is offline   Reply With Quote
Old 02-10-2010, 09:44 AM   #6
prdbloke
Account #: 178235
Most helpful - will report back (after the threatened and unaccustomed snow)
Old 03-06-2010, 10:11 AM   #7
prdbloke
Account #: 178235
Hmmm... the throttle cable is detached for a start - does anyone have a diagram or photograph of how it attaches? I can't imagine you're intended to poke the loose cable end into an aperture in situ. I can't find a step-by-step guide to doing what is needed anywhere on the web, but I do see a lot about stuck throttles on the V8Q. How much dismantling will I be letting myself in for?
Old 03-29-2010, 09:25 AM   #8
P T N B V8
Account #: 50816
Default stuck throttle
Check to make sure the cruise control linkage has not jammed in there, the bushing fails and the rod jams in place- was subject to a recall at some point.
That linkage is under the airbox- removing the air filter housing is just 2 10mm nuts, and lube everything under there for good measure while checking.
Jack
PS: you can remove the idle stabizer and get at the throttle body in about 10 mins and 3 10mm nuts, and then 6 or so 6mm allen bolts. The TB can get crudded up and also stay stuck open. Lots of WD40 and oil can free up the linkages under it too.
P T N B V8 is offline   Reply With Quote
Old 03-30-2010, 04:41 AM   #9
hdmyers
Account #: 150189
be sure your floormats are bolted down.
*** Der Audi 5 Zylinder ist halt der beste Motor ...Der Audi 4 Zylinder is goot too. lol.
Current: 2003 A4 tqm / 223000 km...unitronics , 4x4 stock suspension... purring like a kitty
Past: 2 A4's, 2 A6's, other unmentionables.
hdmyers is offline   Reply With Quote
Old 04-06-2010, 06:02 AM   #10
prdbloke
Account #: 178235
Here's what it was: the bearings on which the throttle butterfly valves sit, and their spring return mechanism, were sticky to an extent you would scarcely believe. presumably as a result of being left in one position for months. Penetrating oil plus a good deal of effort with the hands freed it all up. The rod mechanism that seems so implausible was functioning fine. The whole job need only have taken an hour or so for an able-bodied person.
100, 1999, a4, a6, accelerator, audi, cable, quattro, recall, spring, stick, sticky, stuck, throttle, v8
Forum Jump
