Old 07-22-2016, 01:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Transmission Guides
See related guides and technical advice from our community experts:Browse all: Audi Q5 or Q7 Transmission Guides
Print Wikipost
Transmission Fluid Change?
Old 01-28-2010, 05:49 AM
r1racer's Avatar
Default Transmission Fluid Change?
Anyone done a tranny fluid change yet? I see them done for older models but haven't seen one done for the C6.
Old 01-28-2010, 07:20 AM
utripn's Avatar
its not recommended, you might create more problems for yourself, just fyi.
Old 01-28-2010, 11:09 AM
RDD
RDD's Avatar
my indy audi shop recommended it (I'm at 56k) but I have not done it so far.
Old 01-28-2010, 11:28 AM
tturner2b's Avatar
Why did they recommend it? Did you report an issue or did they just recommend it unsolicited?
Old 01-28-2010, 11:32 AM
r1racer's Avatar
I hear a flush can cause problems. I'm talking about changing the fluid (not using special machinery to flush it out).
Can someone confirm that a flush and a simple fluid change are different?
Old 01-28-2010, 12:25 PM
zzz4's Avatar
I think the recommendation is to drop the pan and do a filter change with the logic being that there will be loose particles after an ATF change that get dislodged and may cause issues. A new filter should catch those.
I am planning to do it this summer on both our cars - they both have 'lifetime' AT fills. I just do not feel comfortable with this proposition because they never specify what "lifetime" means. Lifetime could very well mean "until the AT fails".
Old 01-28-2010, 12:47 PM
r1racer's Avatar
I too feel like it should be done. Especially after seeing how so many of the C5's had old tranny fluid that looked like metallic paint.
Just don't know if I should do it myself or not. My biggest concern would be the fill (you have to get the temp right for an accurate fill). Also bluaparts.com doesn't sell kits for the C6. I'm wondering why.
I guess I'll just do some more research before I decide whether or not to do it myself or take it to the dealer.
Old 01-28-2010, 01:53 PM
am_ver's Avatar
I got mine done twice already.
Once at 46k miles using the Blue ATF TSB
Second time at 49k miles when they changed the Torque converter.
I read that after 75k-80k miles you shouldn't bother changing it because the fluid has become slush and changing it could break your tranny.
We have the ZF (GM) tranny's in our car, or atleast in my A6 3.2. I looked up youtube videos on how to change it... seemed hard, but not that hard.
Old 01-28-2010, 02:47 PM
RDD
RDD's Avatar
They just don't have faith in the so called "lifetime" fluid and have changed the transmission fluid on their own Audis. I have had no issues with the transmission though (*knock knock*).
Old 01-28-2010, 03:14 PM
KevinGary's Avatar
I had mine changed at 35K miles and will do it again at 70K miles. The transmission manufacturer recommneds getting it changed every 45K miles, even though Audi claims it is lifetime fluid.
Quick Reply: Transmission Fluid Change?
