Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk2) Discussion
TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-present
Old 04-13-2012, 05:24 AM   #21
rj45
Good choice, PSS are supposed to be great tires. I switched over to the Conti EC DWS all-seasons, so far so good.
rj45 is offline   Reply With Quote
Old 04-14-2012, 08:08 PM   #22
ely2000
my 2012 tt s line came with toyo tires that are runflats and there stiff
ely2000 is offline   Reply With Quote
Old 05-03-2012, 07:30 AM   #23
Plan_Man
Plan_Man's Avatar
Originally Posted by Plan_Man View Post
Michelin Pilot Super Sport 255/35-19s on the way for a Tuesday install. I will miss my F1 DS-G3s, but alas they are no longer available. I'll post driving impressions ASAP...
Okay, this is a good tire. Unfortunately, it's not as competent as the tire it replaced.
The Goodyear F1 GS-D3 was arguably the greatest summer performance rain tire ever made and was stickier than wet snot on dry roads too. It had remarkable tread life and, when properly inflated (1-2 lbs over the recommended), had nimble characteristics equal to any of the top picks and better than most.
This Super Sport is a comfy tire, but since I was down to the markers on the F1, I don't know how much is new tire tread v. almost no tire tread. The dry grip seems tenacious enough so far, but I haven't had anything other than fog-moistened roads to try out the wet capabilities.
When I picked up the car from the installer, the ride home felt responsive, but when I gave the beast time to cool off and checked the pressures, he'd set them to 40lbs at all four corners. Why installers can't read labels I'll never know; heck, I even get the car back from dealer servicing with the pressures screwed up. Having reset the fronts to 36 and the rears to 31, the response is anything but crisp compared to the F1s. It's not confidence-sapping, but it's certainly not the dynamic alluded to in the Tire Rack survey and reviews (which all must be taken with a block of salt anyway).
I'm going to monkey with front and rear pressures to see if I can dial in some more quickness, but thus far, this experiment in cost/benefit ratios (sub $300 performance rubber) is a mild fail. When you factor in that I generally paid closer to $260 a corner for the GS-D3s, well I'm a little bummed. Still having a blast of course, but a little bummed...
"Whaddya mean 'don't go there'? I live there..."
"Understeer is when you see the tree, oversteer is when you hear it..." (Walter Röhrl, former German RWC)
'09 TTS Prestige, APR Stage I
Plan_Man is offline   Reply With Quote
ad08, as, comparison, contact, dws, extreme, michelin, noise, pilot, ps2, re960as, road, sidewall, soft, sport
