Go Back   AudiWorld Forums > Audi Models > Audi A4 > A4 (B5 Platform) Discussion
Old 01-11-2010, 07:40 PM   #1
reinstone79
Account #: 173357
Send a message via AIM to reinstone79
Default 96 A4 Dash Light Warning Lights Configuration
Ok this should be an easy one for someone out there to answer and maybe get a feeling of ultimate accomplishment.
I recently, a few months ago really, took apart my dash console to replace burned out bulbs and such. In the process, the warning light "windows" (as I will call them) that show the low fuel, oil pressure, and emergency light etc fell out. I thought I put them back in the right place, but when I was down on fuel the big red check engine/EMERGENCY light came on while the fuel gauge light was off. Hence when I filled up the tank, and the emergency warning engine light went off. So obviously I have those two swapped.
But now I'm paranoid I have the others in the wrong spot perhaps, especially since I was chasing my tail on a flashing oil light when I had good pressure and a good switch! So can someone tell me the order of the warning lights?
When you look at the dash from the driver seat.. the cluster of 4 lights should read...?
Top Left Corner = Oil Pressure Light?
Top Right Corner = Water Level/Temp Light? (what does this warn of anyway?)
Bottom Left Corner = Gas/Low Fuel Light (this is where I have the other window instead placed there)
Bottom Right Corner = Check Engine/Emergency Light?
Can someone please verify and give me a heads up?
thanks!
P.S. This is a 1996 A4 Quattro 2.8L V6 with 118k miles and recently serviced about as much as you could imagine.
reinstone79 is offline   Reply With Quote
Old 01-20-2010, 10:45 AM   #2
tmanley
Account #: 168783
http://audi.kris-hansen.com/cluster_bulbs.htm
again Kris was THE MAN on this as I was in same boat. Also not sure about you but MY 4 pane square is a little different from what Kris has.
Mine is as follows ( while looking at it)
water temp oil Pressure
FUEL Warning BLANK..with a cap on it.
Todd
tmanley is offline   Reply With Quote
Old 01-28-2010, 07:40 PM   #3
Er1c
Account #: 77513
Dumb question tmanley, how do you know if you have a trip computer?
Er1c is offline   Reply With Quote
Old 02-01-2010, 04:22 AM   #4
tmanley
Account #: 168783
Er1c, I dont understand your question. Not sure if this is considered a trip computer but I do have a seperate/zeroing mileage indicator under the odometer. As far as a COMPUTER...I dotn have the neat thing mY GTI had where you could flip between mileage since zero'd, fuel avg, current avg speed. etc.
2004, 96, a4, audi, audi2001a4, b5, bulbs, dash, dashboard, dashlight, light, lights, list, overview, warning, warnings
Forum Jump
