Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 Cabriolet (B6 Platform) Discussion
A4 Cabriolet (B6 Platform) Discussion Discussion forum for the B6 Audi A4 Cabriolet
Old 12-16-2009, 11:23 AM   #1
SnugglyGirl007
SnugglyGirl007's Avatar
Default Trunk Release Problems
I have a 2007 A4 Cabriolet 2.0T that will not respond completely to the key fob or the lever in the door to open the trunk. You can hear the zzzzzttt of the motor like it is going to open, but it does not. The only way I can get it to open is with the key manually. The key slot is in the vertical position as it should be and oddly enough this started just after my passenger brake light went out (which has been replaced).
Any ideas?
SnugglyGirl007 is offline   Reply With Quote
Old 12-16-2009, 12:43 PM   #2
Lyman_T
Any chance you didn't get the reflector or the trunk seal secured correctly, and it is interfering with the opening?
2006 Audi A4 3.0L Cabriolet Quattro
Sero sid Serio.
Noli nothi permittere te terere.
Sometimes, the Dragon wins.....did y'all see a knight around here?
It ain't broke 'til WE say it's broke!
Lyman_T is offline   Reply With Quote
Old 12-16-2009, 01:38 PM   #3
SnugglyGirl007
Thanks for responding!
Well the trunk thing started before I actually chaged out the brake light bulb so I don't think that would be it.
Basically, my brake light went out and the next time I tried to open my trunk with my key fob or the door panel it would not work. Just the zzzzzztttttt sound with no click to open.
Old 12-16-2009, 02:48 PM   #4
Lyman_T
I heard somewhere that is indicative of a vacuum line that is now sucking air, since the system is supposed to be vacuum driven. Open the panel where you hear that zzzzzt sound, and you should be able to tell if the vacuum line has come loose.
Sero sid Serio.
Old 12-17-2009, 05:27 AM   #5
RPortela
RPortela's Avatar
good point. I think it's just a coincidence with the whole brake light thing. I know when something goes wrong with mine theres always something else I discover lol
RPortela is offline   Reply With Quote
Old 12-18-2009, 11:48 AM   #6
big_sos
Any ideas?
Isn't this thing under warranty? Why not let the dealer handle it?
big_sos is offline   Reply With Quote
Old 12-18-2009, 12:12 PM   #7
SnugglyGirl007
Thanks for the info, Lyman. I am going to keep that in mind. I actually talked to the dealer and they thought it was a simple lubrication issue. I hope it's that simple. If not, I will have to see if it's covered under warranty.
2003, a4, audi, audiworld, fob, key, lever, malfuntion, open, problem, problems, q5, release, trunk, working
HTML code is Off
