Engine Check warning Light
The engine check warning light is intermittently showing after I clear the faults. There are no symptoms of engine power losses etc.
Anyone has similar problems? It comes intermittently after a week + I clear the faults.
The fault reading below;-
Thursday,12,November,2009,22:49:17:04547
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 DP HW: 26. 06. 03
Component: MOTRONIC ME7.1.1 0006
Coding: 0000133
Shop #: WSC 01236 785 00200
2 Faults Found:
19537 - Engine Temperature too Low
P3081 - 008 - Implausible Signal - Intermittent - MIL ON
17550 - Load Calculation Cross Check: Lower Limit Exceeded
P1142 - 002 - Lower Limit Exceeded
Readiness: 0000 0000
Wednesday,09,December,2009,07:24:15:04547
Coding: 0000133
2 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
P1142 - 002 - Lower Limit Exceeded - Intermittent
Could it be the car battery? It hasn't been changed for the past 4-5years.
Hence the car is still 4++++ KM.
Coding: 0000133
2 Faults Found:
Coding: 0000133
2 Faults Found:
Yep. Try swapping out for a new green top CTS if you haven't changed it for a spell. It's seriously easy to swap and relatively inexpensive to do.
Also - they have these at the VW dealers which MAY be cheaper than the Audi dealers.
Coolant Temp Sensor. Green top.
Easy as hell to replace.
1) Let the car cool down ALL THE WAY (unless you like hot liquid in the face - not that there's anything wrong with that)
2) Find the CTS
3) Drink a beer
4) Unclip the harness on the CTS
5) Drink another beer
6) Pull the little clip off of the CTS
7) Pop out the old CTS and replace with the new CTS
8) Replace clip on CTS with a new clip because you broke the original clip removing it
9) Drink another beer
10) Hook up the harness connection
11) Wipe hands on pants and finish that beer.
Easy as pie, took me like 5 minutes and I didn't spill a drop of coolant. It will take you longer to drink the beer than to replace the CTS.
2) Find the CTS
3) Drink a beer
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
