Old 07-25-2016, 09:21 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi Q5 or Q7 Brake Guides
Print Wikipost
DIY Brake Fluid Flush
Old 10-31-2009, 03:13 PM
r1racer's Avatar
Default DIY Brake Fluid Flush 2005 C6
Brake Fluid Flush- 1 Hour. You will need 1 liter of recommended dot 4 brake fluid. I used ATE Super Blue so I could see when the gold fluid was flushed out. I will use the OEM gold on my next flush. You will also need a Motive pressure bleeder (recommended), about a ¼ inch bleed plastic tube (comes with Motive pressure bleeder), catch container of some sort, light, flathead screwdriver, funnel. rubber gloves, towel and an 11mm wrench
So there are about 4 ways to do a brake fluid flush. These methods include gravity flushing/bleeding, pressure flushing/bleeding, vacuum flushing, brake pedal bleeding. I cover the pressure flush/bleed method as it’s the best overall way to do the flush for the DIY. However, if you don’t want to spend 50 bucks (trust me it’s worth it) on a pressure bleeder, then the gravity method is the safest, but most time consuming method as all you have to do is open all the bleeder nipples and let gravity drain the fluid out. Just make sure the car is jacked up and that the bleed line and catch container are below the caliper. Also make sure that the reservoir NEVER runs empty. The other two methods, using the brake pedal (can damage the seals in the master cylinder if the brake pedal is depressed too far) and vacumming (requires expensive tools) are not recommended for the DIY.
So first things first, DO NOT LET THE BRAKE FLUID RESERVOIR GO EMPTY!!! I cannot stress this enough. If you do, then you have to use vag-com to bleed your ABS pump. I will post instructions at the end in the event this happens. If you don’t have vag-com then your car will have to be towed to your mechanic / dealer as the car will not be drivable. Also, be careful not to get any brake fluid on your paint, clothes, hands…as brake fluid will ruin just about anything it touches.
1) Throw on some rubber gloves, pop the hood and remove the black cover over the brake fluid reservoir by pulling off the rubber gasket that is holding it in place and the simply pulling it out.
2) Next, pop the hood, rap some towels around the brake fluid reservoir, takeoff the brake reservoir cap. Again make sure brake fluid doesn't get on your paint.
3) Remove most of the brake fluid using a turkey baster, syringe, a baby snot sucker thing (I used one of my daughters, lol). DO NOT SUCK IT ALL OUT, leave some as you do not want air entering the system. Also, obviously DO NOT REUSE the turkey baster in the house. If you don't have one you can just bleed it out. Sucking it out just saves a little time.
4) Fill the reservoir with your new fluid and leave the cap off.
5) Attach your EMPTY pressure bleeder to the reservoir and pressurize to 10-15 psi. Check the pressure for about 30 seconds to make sure the pressure remains constant. If the pressure drops, then there is a leak somewhere. Tighten all connections and make sure the pressure remains constant.
6) Next depressurize the bleeder by removing the cap to the BLEEDER, not the cap connected to the reservoir. ALWAYS depressurize by opening the cap on the bleeder, not on the reservoir!
7) At this point you have the option of filling your pressure bleeder with brake fluid or leaving it empty and just using the pressure to push the fluid through. Placing 1 liter of fluid in the bleeder ensures that the reservoir will not run dry. Connect to the reservoir and pressurize to 10-15psi. Do not go over or you could bust some **** up.
8 ) Jack up the rear of the car if you want more space when getting under the car. I didn't bother to jack up the rear of the car. I just slid underneath the car. I really didn't even have to do this as you can work next to the wheel and reach behind the wheel and access the nipple. That's how I later did the fronts.
9) If you choose not to fill the bleeder be sure to check and refill your reservoir at least once or twice when doing each of the rear lines. This ensures your reservoir does not run dry. Starting with the right rear of the car (if you are sitting in the driver seat), locate the bleed screw on the caliper.
10) Remove the nipple cover. Place your 11mm wrench on the screw. Connect your bleed tube, then loosen the screw. Again, for the rears, if u r opting not to put fluid in the bleeder, allow some of the old fluid to drain out (about 20 to 30 seconds) then close the nipple and add more fluid. If you are putting fluid in the pressure bleeder just allow it to drain until you see the new fluid being flushed. Again I used the blue fluid to see when all of the old fluid was flushed out. Without it, it will be difficult to determine when the new all of the old fluid is flushed out unless you know how much should be drained, Once I saw the blue fluid draining out, I continued to let it drain for an additional ten to twenty seconds to be sure all of the old fluid was out of the line.
11) Repeat the process for the left rear, right front, left front, IN THIS ORDER. Next go to the front and jack up the car. No need to take the wheels off but you do have to jack the car. It gives you more room in the wheel well to just reach around the wheel and pull the nipples off, attach my wrench and tube and loosen the screw. The front will flush quickly so if you are not using fluid in the bleeder you don't have to worry about the reservoir running out of fluid. Just make sure you add fluid after each line.
12) Now that all of the fluid has been flushed you need to check the level in the reservoir and either add or remove fluid so that it falls in between the min / max levels.
14) Check brake pedal pressure (should feel the same or better), check for leaks and dispose of unused / old brake fluid properly,
15) Vaccum out any leaves before you put the black cover back on, clean up, test drive and you are done!!!
Instructions from ross-tech for bleeding your ABS pump if you accidentally allow the reservoir to go dry:
This procedure details how to bleed the ABS pump when replacing brake fluid. This procedure is NOT necessary unless your ABS pump has gone completely dry. For normal brake work including fluid replacement, hose replacement, pad replacement, etc. this procedure is NOT necessary
There are certain test conditions that must be met before doing this procedure:
Vehicle must on a lift or safe jack stands with no wheels touching the ground
Ignition should be in the "On" position
Procedure for Bleeding the ABS Brake Pump on VW Passat and Audi A4/S4, A6/S6, and A8/S8:
[Select]
[03 - ABS Brakes]
[Basic Settings - 04]
Group 002
[Go!]
This will trigger the ABS pump to turn on for about 10 seconds. You should hear the fairly loud pump clicking during this time.
Click the [Done, Go Back] button and you're all set
Old 10-31-2009, 04:05 PM
r1racer's Avatar
I'll probably do the rear pads tomorrow.
Old 11-01-2009, 07:28 PM
am_ver's Avatar
Nice.. Thank you for posting these instructions!! Very helpful!
Mods, can we please make this a sticky?
Old 01-24-2010, 11:28 PM
makav3li's Avatar
What will happen if I dont do the vag-com bleed on the abs pump?
I dont have access to it and I'd like to get it drivable asap, so what would happen if i just do the manual bleed using the caliper nipples and some1 pushing on the peddles?
Old 01-25-2010, 05:34 AM
mystrodo's Avatar
R1racer..you've did it again, another excellent teaching submission for those who are hesitant work on their Audi and would like to save some big $$. Anyone who has read your 55K knows your capabilities....thanks
Old 01-26-2010, 11:03 AM
r1racer's Avatar
From what I understand, you MUST have Vag- if you let the reservoir go dry. The pump has to be electronically bleed.
If you are asking if you need vag to do a flush the answer is no. Only if you let air get into the ABS pump via the reservoir.
Old 01-26-2010, 11:24 AM
zzz4's Avatar
Where do we get the blue fluid? I understand the purpose of a different color is to easily recognize when the old fluid has been flushed.
Old 01-26-2010, 12:27 PM
r1racer's Avatar
I got my pads, power bleeder and fluid from ECS Tuning:
http://www.ecstuning.com/Audi-B6_A4-...g/Fluid/ES111/
You only need one litre of fluid (unless you are excessive in the amount of fluid you bleed).
Old 01-26-2010, 12:31 PM
makav3li's Avatar
so the problem i have is this, i removed the whole abs control unit and the pump (being stupid) to get it rebuilt because the control module is bad, so it dumped all the brake fluid and id imagine the pump is bone dry now, if i install the pump and do the bleed without the vag-com, will it burn out the pump? I plan on doing the vag-com later on maybe even that day but not necessary at the same time as the bleed.
Old 01-26-2010, 12:42 PM
r1racer's Avatar
I doubt it will burn out the pump but I don't think you can bleed it manually (using the pedal). It has to be done electrically. Try vaglocator.com and see if someone can help you out. It should only take a few minutes to bleed using vag.
Quick Reply: DIY Brake Fluid Flush
