Old 10-25-2009, 08:58 AM   #1
bfbarosky
Account #: 171978
Default A6 Steering Column Cover Removal
So far I have removed the 2 torx screws from the underside of the cover & the 2 phillips screws in the front of the lower cover. Lower cover just will not come off. Appears to be some attachment point near the steering wheel, but I can't see anything.
I need to replace the W/Washer lever assembly (my 19 year old broke it off somehow).
HELP!
bfbarosky is offline   Reply With Quote
Old 10-25-2009, 09:57 AM   #2
radhaz
Account #: 105935
radhaz's Avatar
Looks like you need to remove the steering wheel.
2011 A3 S-Line Monza Silver Metallic
posting from central California
radhaz is offline   Reply With Quote
Old 10-25-2009, 10:28 AM   #3
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
I've done this, but I don't remember. When I did the evaporator swap, I used Bentley. I have a fair amount of Audi experience and mad skilz, but after using Bentley it is clear to me that I would have broken a ton of plastic parts if I had not carefully followed the Bentley.
4Driver4
Growing old is mandatory; growing up is optional.
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
2003 Mini Cooper S (just because)
1995 Mazda Miata, Superdupercharged(anti-Audi)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
Old 10-27-2009, 12:21 PM   #4
Boston Driver
AudiWorld Expert
Account #: 69482
Boston Driver's Avatar
There is one more torx bolt near the tilt lever on underside, but you will need to remove the steering wheel anyway to replace the wiper stalk.
Refer to this article which gives more detail on the stalk replacement (for the signal stalk but they are attached to each other): http://www.audiworld.com/tech/elec162.shtml
Refer to this writeup for info on the steering wheel column trim for a non-4.2 (my 2.7T):
http://forums.audiworld.com/showthread.php?t=1702901
Good luck!
2002 A6 4.2 Sport...with a few things added
Boston Driver is offline   Reply With Quote
Old 10-31-2009, 05:21 AM   #5
bfbarosky
Account #: 171978
Good luck!
Many thanks. This is my project for next weekend. Need to find the parts first.
My A6 also has the turn signal problem you mentioned. But mine makes a very fast clicking noise in the dash, behind the radio - Relay Problem???
Usually, after I operate the 4-way flashers for a few minutes, the turn signals work, but only for a few seconds.
2001, 2002, a4, a6, audi, b6, column, cover, removal, remove, removing, road, steering, tt, wheel
Forum Jump
