How to disconnect transmission cooler lines from radiator
Old 10-19-2009, 06:05 AM
4ever Quattro's Avatar
Default How to disconnect transmission cooler lines from radiator
Replacing the radiator on myy 96 A4 auto tranny. I think everything should be smooth going, except for the tranny cooler lines. They are stuck in place. I took out the bolts, and tried to pull/wiggle/tug at them, and they won't even budge at all.
Is there a trick to getting them out?
Thanks.
Old 10-31-2009, 10:29 PM
ky90025's Avatar
I have a 97 A4 with 2.8 AFC engine (auto). The trans. oil cooling lines attach to the radiator with one bolt for with line. There is a o-ring on the tube that needs to be replaced so have them ready to replace. They should just pull out unless yours is different from mine. Wiggle it a little bit to see if they will release it.
Old 12-06-2009, 02:31 PM
Thanks. The top line was stuck, I had to pry it (VERY carefully) using a screw driver. The bottom one was really easy.
Shorty 5150
06-15-2009 03:40 PM
Lauda81
08-05-2008 03:04 AM
dm.A4.B5
12-02-2007 04:47 AM
rusf77
09-29-2007 06:20 PM
sugaryling
Audi allroad
08-19-2007 06:37 PM
Quick Reply: How to disconnect transmission cooler lines from radiator
