KevinGary and Dr. Cold's TSB Library
Old 10-19-2009, 02:56 AM
KevinGary's Avatar
Default KevinGary and Dr. Cold's TSB Library
Thanks to Dr. Cold all of my TSBs have been placed in one spot. Perhaps the moderator can make a sticky of this post. Here is the link to the TSBs.
http://www.uberlame.com/a6_tsb/Audi%...TSB%20List.htm
Kevin
Old 10-20-2009, 10:21 AM
Head Cat Herder
Kris Hansen's Avatar
I'd love to add those to the wiki..
Old 10-22-2009, 07:10 PM
WNT2FLY's Avatar
Thanks for the efforts!
(FYI PrimoPDF is free and doesn't watermark your PDF docs.. been using it for years!)
WNT2FLY's Avatar
Forgot to mention
The TSB http://www.uberlame.com/a6_tsb/Headlights%20vibrate.pdf says if no damage found, and adaptive headlamps are affected (which I do have), then refer to TSB 2018787
Anyone know which is 2018787?
Old 10-23-2009, 08:43 AM
am_ver's Avatar
Originally Posted by WNT2FLY
Forgot to mention
I won't be able to look that up unless I open each of the TSb's and look at the number on the TSBs on my hard drive. Maybe KevinGary has an easier way to search his repository.
Old 10-23-2009, 09:26 AM
mystrodo's Avatar
Forgot to mention
If TSB 2015445 doesn't fix the problem then you need to refer to 2018787/2 the latest TSB for vibrating HID headlights, when you take it to Audi refer to the second number.
I used the update feature of the Bentley Manual to get the TSB but I still haven't the time to figured out how to copy or make a PDF.....sorry.
Old 10-23-2009, 11:18 AM
am_ver's Avatar
Its pretty straightforward ... download a pdf convertor (http://www.primopdf.com/) and install it. Now, if you want to copy something or converted to pdf, hit the print button. If your primo pdf is installed correctly, you should see primo pdf as a printer. Select that, and you will then be asked on where you want to store this file. Select the right path and hit ok - and you're done. You now have a pdf file with the information from the Bentely manual.
Here are some pics
Old 10-23-2009, 05:58 PM
mystrodo's Avatar
Thanks Am-ver..I was looking for that software.
Old 10-23-2009, 06:18 PM
mystrodo's Avatar
Forgot to mention
Send me a PM with your email and I'll email the latest PDF
Old 10-24-2009, 01:52 AM
KevinGary's Avatar
I just took a look at your list of the TSBs available at the erwin site and it does not list the requested TSB. I have also looked at my internal list of TSB numbers in my database and I also don't have it. If you and I can't find it, it must be hiding in a good spot.
Quick Reply: KevinGary and Dr. Cold's TSB Library
