Old 09-25-2009, 08:14 PM   #1
rossej
Default Oil Temperature Sensor LOCATION - 99 2.8L
Does anyone have a good image of the oil temperature sensor location for a 1999 A6 2.8L?
My gauge doesn't move and fixing this is the next project I want to entertain. I have the Bentely Service manual but it doesn't give a very good description of where this is located. All I know is that is half way up the front of the engine of the drivers side. Again, pictures would be very nice...
Thank you.
rossej is offline   Reply With Quote
Old 09-26-2009, 03:26 AM   #2
4Driver4
Tech Guru
4Driver4's Avatar
Sensor rarely fails. Have you done any diagnosis with VAG-COM?
4Driver4
"Never give up the throttle until the bitter end." -RC
2003 Mini Cooper S (Fun!)
1995 Mazda Miata: the anti-Audi
1999 Mazda Miata SSB: track beotch
2003 GMC Yukon Denali XL: the anti-earth
2004 Dodge Dakota: hey, at least it's stick and 4x4
Old 09-26-2009, 09:01 AM   #3
thejulex
It is on front of engine, immediately to the right of crankshaft, between crankshaft and AC pulleys, just below the belt tensioner and therefore might be hard to spot when looking from above.
Anyway, use http://www.vagcat.com/epc/ (register) to see diagrams.
Thanks.
thejulex is offline   Reply With Quote
Old 09-26-2009, 10:10 AM   #4
rossej
I don't have the VAG-COM software at the moment so I haven't diagnosed. Anyone in Pullman, WA/Moscow, ID area with VAG-COM?
I'll give you a run down of the symptoms: When the car is turned on I can see the oil temperature gauge move slightly. But is stuck of the most left position (indicating the coldest oil temp). A couple of weeks ago I drove it 300 miles including climbing over a mountain pass and the oil temp gauge never moved. I'm positive the oil was hotter than the gauge indicated.
Old 04-06-2010, 10:35 PM   #5
rossej
I finally purchased VAGCOM. Hooked it up to the car and tried to see if the software would give me a temperature reading for the oil. I couldn't get a reading at all, essentially it said 0.0.
Are there any additional ways to test the oil temp sender with VAGCOM?
Does anyone know the wire route to the ECU?
Any input is appreciated.
Old 08-13-2010, 11:35 AM   #6
Airbag
I have this EXACT issue ..I would imagine grounding the sender wire would peg the guage .. or defect it to maximum when disconnected ... the dissapointing part is I just did a timing belt after starting the car and it was probably right htere in front of me for testing doh !!!!
Airbag is offline   Reply With Quote
Old 08-13-2010, 04:44 PM   #7
Airbag
update,,,, My 2000 for sure has the oil temp built into the oil level sender and must be replaced with OE unit ( Hella) . Others WILL NOT WORK >..
here is a link to the site with the cheapest one I found.. will update again after my next oil change ..
http://www.europaparts.com/oil-level...j0907660b.html
Old 08-13-2010, 06:30 PM   #8
mpw
Thanks! I've been looking for this. I just ordered one myself.
2000 A6 2.7T 6MT
Ebony Pearl/Tungsten
mpw is offline   Reply With Quote
Old 08-14-2010, 12:47 PM   #9
Airbag
your welcome . just don't grab the last one before my order ships out
Old 01-20-2011, 09:18 PM   #10
A6force
2001 Audi A6
Default Similar issue
I have a 2001 2.7t and had a similar issue. The oil sensor light would go on and off and the temp gauge would stop working when the sensor light went on. i replaced it with a sensor made by Meyle, the sensor light stayed off but now the oil temp gauge doesnt work. I plan on buying the oem part now. I know this post is long after the original, but for anyone considering the cheaper replacement oil level sender... DONT DO IT! buy oem.
A6force is offline   Reply With Quote
18t, 1999, 2000, 28l, 42, a4, a6, audi, engine, locate, located, oil, s4, sensor, temp, temperature, v6
