| A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007-present |
#21 | ||
2005 Audi A6Join Date: Aug 2009
3.2 LOADED C6, LOW KEY LUXURY!!! Last edited by r1racer; 09-18-2009 at 06:25 AM. |
#22 |
I just stick with stock plugs.
3.2 LOADED C6, LOW KEY LUXURY!!! |
#23 |
2006 Audi A6Join Date: Apr 2009
Hey racer, Did you do the fuel filter yet? Is it hard/complicated?
2006 A6 3.2 Quattro, Midnight blue/beige, Nav (retrofit), Koni FSD + Eibach springs, LED license plate light, Premium, Cold Weather, Sun shades, Debadged, V1 hardwired (fusebox) - CD on dash, LED DRL, K-MACS, RS Style grill. You can't call me a badge-ho - I'm de-BADGED! Past: 2008 BMW 335i convertible (e93) 2007 BMW 335i coupe (e92) 2006 BMW 325i sedan (e90) Banned from QuattroWorld |
#24 |
Nope not yet. I should have time tomorrow.
#25 |
Good write-up r1racer... Do you know all this applicable for the 4.2 engine? I'm at 54K and will be doing this soon. Thanks
#26 |
Don't quote me on this but I belive that the oil change (more oil obviously), spark plugs (not sure what the gap is though), air filter, cabin filters and lubing are the same. Not sure about the fuel filter installation as the part number is different for the 4.2L.
All the part numbers are the same except: Oil filter Fuel filter
#27 | |
#28 |
Thank you racer - You are the best!!
Attaching TSB for oil filter change "When changing the oil filter and installing the new filter seal(s) in the oil filter housing, special attention is required. Note: Be aware that this seal can be installed inside-out, which must be avoided to prevent oil leaks." I did the fuel filter replacement as well yeesterday. I put the car on ramps which worked great for me. The only hard part was taking those pipes out - the blue one came off easy. The black one on the same side had to be pressed on both the sides and removing this was harder than the blue one. The pipe at the other end had some kind of clippy which I was not able to see initially.
2006 A6 3.2 Quattro, Midnight blue/beige, Nav (retrofit), Koni FSD + Eibach springs, LED license plate light, Premium, Cold Weather, Sun shades, Debadged, V1 hardwired (fusebox) - CD on dash, LED DRL, K-MACS, RS Style grill. You can't call me a badge-ho - I'm de-BADGED! Past: 2008 BMW 335i convertible (e93) 2007 BMW 335i coupe (e92) 2006 BMW 325i sedan (e90) Banned from QuattroWorld Last edited by am_ver; 09-12-2009 at 09:38 AM. |
#29 | |
#30 |
I dont have the car manual, so what motor oil should I use on my 06 4.2? I live in MA so winter temps can be brutal sometimes. Thanks
| Tags |
| 2005, 325i, 42, 55k, a6, air, audi, bit, diy, drain, filter, oil, plug, service, size, torx |
