#1 | ||
#2 |
I have spent at least another 10 hours on this one trying to find the route cause.
I finally purged all the hoses and checked the connectors in the tank that connect the following together: Baffle Housing Fuel Pump Suction Pump - left & right hand side Fuel return to baffle housing I blew them all through with compressed air to make sure that there were no blockages. Then I run up the pump on it's own by powering up fuse 28 from the battery. I noticed that not a lot was happening and the pump was virtually running dry. I then primed the baffle housing with diesel and an almighty gurgle came from the left hand side of the tank. All of a sudden the chamber was filling and loads of air was being pushed out into the housing. I put everything back together again and tried the car. It eventually worked after about 14seconds of cranking on the key. It has been fine ever since!!! It must have picked up some crud from the bottom of the tank which prevented the suction from working properly!!!! I hope it doesn't happen to you guys. |
#3 |
![]() Join Date: May 2006
Interesting thread. A few of the Q7 guys have had similar issues with gauge reading above reserve yet running out. Its not specifically a TDI thing. In a couple of cases the cars have been in service for days (maybe waiting for parts). The latest case is at this time unresolved despite all components including gauge being replaced.
It appears the display reading can be shifted via VAG Com. Have you tried running into the red since?
Q5 related Link to Q5 Spreadsheet *Exterior pics* *Interiors* Q7 related Link to Q7 Spreadsheet *Exterior pics by color, model and rim size* *Interior pics* A4 S4 Spreadsheet Link to Q3 spreadsheet |
#4 |
Thanks for data on this one. I have run the car down to reserve since and it was fine. So I guess the problem was with the suction pump losing pressure due to crud in the pickup from the other side of the tank.
#5 |
Hi guys ,i have the same problem with my audi a6 2.5 tdi 2003.The car had been of the road for about 3 months due to injection pump failure,after replacing the injection pump and coding the glow plug light was flashing...pulled out the same code g210 low level fuel sender,got a replacement from audi but that didn't solved i have the same code and the light still flashig in dashboard....Now i just seen your post there and i don't know witch is the baffle housing,is that the plastic housing around the lift pump in the tank?
#6 | |
If the baffle housing is not primed (i.e. bone dry) it won't suck up the diesel from the other side. Try doing what I did by priming the baffle and running the pump in isolation. Then see if the baffle continues to be filled under the pumps pressure. Good luck |
#7 |
Right,i opened the pump in the tank again and there is no pump in the tank,is just the plastic housing ,level sensor and another small sensor inside the plastic housing. The car is a 2003 a6 engine code BCZ,em i missing somthing,is there another acces to the tank other that the one in the boot? Thankyou
#8 |
OK...you're absolutely right...If I remember correctly there is a cylindrical plastic housing and the pump is contained as part of this unit.
I have an avant and the access plate is under the rear seat on the right hand side.As far as I can remember this is the only access. Hope this helps |
#9 |
right...totaly diffrent,there's nothing under the seat apart from the yaw sebsor ....star wondering if a wire could touch the body somwhere shorting out...
| Tags |
| 01441, 25, a4, a6, air, audi, battery, blockage, fails, fuel, fueling, g210, start, tdi, technical, term, vagcom |
