VAG-COM Discussion
How to "reset" battery meter on MMI High?
Old 08-07-2009, 10:26 AM
Peavey's Avatar
Default How to "reset" battery meter on MMI High?
As topic explains; Where in Vag Com can I reset the battery meter on the MMI high?
The car is an 2003 Audi A8
Thanks in advance
Old 08-07-2009, 10:32 AM
Theresias's Avatar
Sadly the explanation doesn't really cut it. What exactly do you mean by "reset" and why would you wanna do such thing?
Old 08-07-2009, 10:41 AM
Peavey's Avatar
Okay, sory
I've charged the battery atfer it was empty but the power meter still shows only 10% and the car is en emergency management mode.
So I need to recalibrate/reset the battery meter
Old 08-07-2009, 10:47 AM
Theresias's Avatar
Post an Auto-Scan from the vehicle in question please, I'd like to take a look at some of the control modules and their software versions.
Additionally please provide a control module map from your battery regulation control module (#61).
To create a map, please perform the following procedure:
Start VCDS
[Applications]
[Controller Channels Map]
Address: 61
Function: Meas. Blocks/Adaptation
Output: Pre-Label File
[Start]
After creating the "map" files, you can find them in the /VAG-COM/Logs/ folder - please send it to me via email (see signature for address). If you are sending files, please attach an Auto-Scan from the car(s) you obtained the maps from as well.
Old 09-02-2010, 08:22 AM
Limoncello's Avatar
Sebastian, I would also like to know if is possible to reset the battery meter. I have an 05 A8, after 2 weeks away, i started the car and started getting power management warnings, Batt meter is just below 10%, but, the car and battery appear to be fine, my only problem seems to be the batt meter giving false readings (it remains on 9% no matter what) which causes power management to give low battery warnings.
Can VAGCOM fix this by clearing the error, reseting the meter etc
Old 09-03-2010, 02:21 PM
Audiworld Premium Sponsor
Uwe@Ross-Tech.com's Avatar
Supriously low battery readings in the MMI are usually due to one of two things: Really old firmware in some of the car's control modules (which needs to be updated at the dealer) or charging the battery with the charger connected incorrectly, so that the battery management module didn't see the current going into the battery.
We can usually tell if the firmware in the modules is outdated from an Auto-Scan.
-Uwe-
http://www.Ross-Tech.com
Old 10-19-2010, 07:27 AM
Limoncello's Avatar
Default Update
Ive used vagcom to recode the battery , so it thinks a new one has been put in, since then no more problems, If it drops again i will replace the battery anyway
Old 10-30-2010, 11:32 PM
jabichocu's Avatar
saddly my car (2009 a4 b8) has no such "battery regulation control module (#61)"...where can I recode my battery then???
Old 10-31-2010, 12:34 AM
Limoncello's Avatar
Only cars with MMI have to recode the battery when changing it, if you are changing the battery on the B4 you dont need to code the batery. but i think on the B4 you do need to do some recalibrations
what is the issue that you have
Old 10-31-2010, 03:32 AM
jabichocu's Avatar
I donīt think the meter is working well cause it says my batery is 80% and after charging it to full capacity the meter is still stuck in 80%! My a car is a B8 with concert3 radio
Quick Reply: How to "reset" battery meter on MMI High?
