| S4 / RS4 (B5 Platform) Discussion Discussion forum for the B5 Audi S4 & RS4 produced from 1998-2002 |
#1 | ||
#2 |
when bleeding my brakes, it did that when the fluid got low and went away when i refiled it. Maybe your fluid is a little on the low side and you hit a bump, turned hard or something to move the fluid away from the sensor? Just check the fuid incase. Hopefully it will be that easy
Or you can just throw money at it, that should fix it. Good luck
#3 |
2000 Audi S4Join Date: Apr 2009
^+1
The brake light will flash like that if you're nearly bottomed out on the fluid but there's just enough left to cover up the sensor - check that fluid level and you'll know right away if that is your problem. |
#4 |
Check the fluid level, overfilling or underfill can be a problem. I had ghost brake warnings as well. Could also be a contact problem. My guess is that it is intermittent and will go away.
Stage I 01.5 S4, silver. Integrated V1, compass. Custom boost gauge to match interior. Painted brake calipers with stickers. DTM wheels with Falken ST-115. Winter tires and wheels. Lip spoiler. Sunroof wind deflector. 6 cd changer. Audi sport floor mats ABT chipped M-box |
#5 |
2000 Audi S4My Garage Join Date: Jun 2009
ive been having that problem for about a week or 2 now, and i have all new pads with plenty of life, i figured i got some paint on a the a sensor or somthing that might not have been taped well enough when i painted my calipers, but im gona check fluid when i get home now, but i had no problems prior to painting
#6 |
Thanks for all the responses. Gonna check the fluids tomorrow am. Called my Audi tech and ran it by him, he said that its not uncommon for B5 A4 and S4's to have the ABS control module go and that may be it. A new module is $800!!! However, there is supposedly some places that will repair your old one and warranty their work. Anyone know of such a shop should I need it?
#7 |
Its not the ABS, you can get your ABS rebuilt for much less than $800 if you need it.
#8 |
I checked my fluid levels and it is not a fluid issue. It was right on spot. How else can I rule out anything other than the module?
#9 |
When the light flashes does your ABS work when you slam hard on the brake pedal? I had exactly the same problem which turned out to be the ABS module. I found a place who reconditioned the unit for £100.00gbp It cured the problem. Good Luck mine got progressively worse until the light was flashing all the time which realy gets on your nerves and beeped everytime the ignition was turned on.
#10 |
I have yet to test it by panic breaking, but everything points to it being the module. I was able to find a couple places, thanks to the forum, that will rebuild my module and warranty their work. Thanks everybody for the help!
| Tags |
| 1998, 2005, 2007, a3, a6, a8, audi, brake, driving, light, pad, q7, s4, tt, warning |
