Old 07-18-2009, 04:28 PM   #1
nimesh
Account #: 160134
Default FUSE BOX?!
HEY GUYS i can t find my owners manuel do you guys know where the fuse box is for a 2007 a8L... and i was wondering what fuse number is the fuse for my rear license plate lights they both arent working! lol
nimesh is offline   Reply With Quote
Old 07-19-2009, 08:20 AM   #2
Audis or VWs 4Life
Account #: 28993
The car has 3 fuse boxes. Each fuse box has short description as to what certain things are. There is fuse box that you can get to when you open the driver or front passenger door. Open the front driver car door. Look to the left of the headlight switch. You should see a plastic panel that is not visible when the door is closed. (its the side/end of the dashboard) If you kneel down and look at the under side of this end panel you will see two holes about the size of your car key blade. Use a flat head screw driver or insert your key and pry back the side panel.
The passenger side door should have the same arrangement.
In the trunk I forget which side has the fuse panel. But a flat head screw driver will allow you to turn the quarter turn black plastic screws on the left you'll see the DVD drive for the nav, and on the right you'll find the battery. One of those two sides should hold the fuse box.
Current:
2012 S4 Blk/Blk, Premium Plus, Nav, Sport Diff, Keyless Go, Parking Sensors, Stainless Steel
Former:
2006 A8L Blk/Blk
4 Zone, Dual Pane, Heated & Cooled Seats, and a few other goodies.
2004 S4 Nogaro Blue/Silver
2000 S4 Blk/Blk
2002 VW Jetta TDI Silver/Blk
1990 200 Quattro Red/Tan
1991 V8 Quattro 5spd Stick (rare) Blk/Blk
1987 5000 Quattro 5spd
1983 5000 S 5spd (263k miles on the original clutch!)
1979 911 Targa -- Ran on av gas.
Audis or  VWs 4Life is offline   Reply With Quote
Old 07-19-2009, 08:34 AM   #3
MP4.2+6.0
Senior Member
Account #: 26081
Default There are fuses in the trunk too...
on both sides. The lighting wires generally head toward the rear lights from the passenger side where the battery is (though I don't know about the license plate lights).
Simple as it may sound, you may want to check the bulbs first. Yes, it's possible they both burned out.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here.
Current #2: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery 7/2013 (pictured at Ingolstadt)
Prior (each modded): 2000 C5 A6 4.2 & '96 C4 A6 2.8Q, both still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS
helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
MP4.2+6.0 is offline   Reply With Quote
Old 07-19-2009, 04:11 PM   #4
Mister Bally
Account #: 102428
I agree with MP4.2+6.0
I had one burnt out and the other had the glass very dark so it would probably burn out real soon. They are common pretty standard bulbs available from Pep Boys etc. No need for dealer parts for them.
Mister Bally is offline   Reply With Quote
2005, 4000, a4, a6, audi, b7, box, cabriolet, forum, fuse, licence, license, light, lights, plate, rear, s4
Forum Jump
