P1138 P0327 P1136 98 2.8Q
Old 06-30-2009, 07:36 AM
Drpheonix's Avatar
Default P1138 P0327 P1136 98 2.8Q
So, I had a friend of mine who has the vagcom software and a cable, check my a6 for error codes, since i noticed that the CEL never ever lights up when turning the key on ON position.
here's what we found:
VAG-COM Version: Release 409.1-US
Control Module Part Number: 4D0 907 551 AH
Component and/or Version: 2.8L V6/5V MOTR AT D03
Software Coding: 06252
Work Shop Code: WSC 02325
5 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
17546 - Fuel Trim: Bank 2 (Add): System too Lean
P1138 - 35-10 - - - Intermittent
16711 - Knock Sensor 1 (G61): Signal too Low
P0327 - 35-10 - - - Intermittent
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 35-10 - - - Intermittent
Control Module Part Number: 4B0 927 156 G
Component and/or Version: AG5 01V 2.8l5V USA 8509
Software Coding: 00000
Work Shop Code: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Since i just bought the car, we cleared all the codes, waited a week or two, and we just rechecked yesterday, and 4 codes still come in:
I have a small exhaust leak at the flexible part right before the catalyst canisters, but i was going to begin by checkin all my vaccum lines. what else should i be checking ? MAF ? o2 sensors reactions while running? coilpack ?
thx
Old 06-30-2009, 07:42 AM
Drpheonix's Avatar
forgot to mention that the car sometimes (quite often in fact) hesitates while accelerating smoothly.... if i floor it, it will take it but the car will still sometimes hesitates, sometimes not. there is definitely an intermittent loss of power.
The motor seems to rough idle just a little bit (just enough to make the car shake a little, like +/- 100rpm). This problem is also intermittent....
and what about the implausible signal on the brake light switch ? ??
thx a lot!
Old 11-29-2009, 01:16 PM
Crazy Marty's Avatar
Default Knock Sensor 1 (G61): Signal too Low
the implausible signal on the brake light switch is a result of not depressing the brake pedal during the scan.
guido_TT
VAG-COM Discussion
15
03-09-2007 11:11 AM
rennteknik
06-06-2006 01:42 PM
SLG123123
05-30-2003 02:52 PM
OneEighty
TT (Mk1) Discussion
05-27-2003 06:28 AM
Quick Reply: P1138 P0327 P1136 98 2.8Q
