| A4 (B5 Platform) Discussion Discussion forum for the B5 Audi A4 produced from 1995-2001 B5 FAQ |
#1 | ||
#2 |
There is a possibility that the warning light is due to a faulty oil pressure warning switch - they do break. The only way to diagnose this is by connecting up an oil pressure gauge in its place (you need a gauge, this is probably the most accurate way) and taking some measurements, or just replace the switch - they are cheap at mailorder parts places, but this is not a very accurate way of performing a diagnosis. If you use a gauge, you will need to know what the spec is for pressure at various RPMs and conditions.
Have you owned the car since new and/or seen records that it had 3000 mile oil changes its entire life? My 1996 V6 used to get 3000 mile dino oil changes (before I was enlightened to the value of synthetic) and has gross looking inner valve covers, but I do not have the oil pressure problem that you are seeing. Last winter I took off the lower oil pan to fix a leaky gasket and the oil pickup screen was perfectly clean.
1996 Audi A4QM 2.8 (current) 1984 Audi 80CS (company car in Europe) 1978 Audi Fox (RIP) 1973 Audi 100LS (RIP) |
#3 |
I've owned the car since 2000 so I'm pretty confident about the oil changes being regular throughout that time period.
It would leak/burn when the valve covers were off, so it might have been low here and there, but I was pretty good about it. |
#4 |
And yes. I've been enlightened about synthetic as well. Synthetic from here on out for me.
#5 | |
#6 |
2000 Audi A4Join Date: Sep 2002
The PO used unapproved sealant when he replaced the oil pan. Over time, the oil turned this into a gummy mess, which was then sucked up by the oil pump, and required that it be replaced. If it were me in your situation, I would pull the oil pan, and observe what's going on up there. I think the ticking sound rules out a bad sensor, because that is indicative of improver oil circulation. You may want to VAG-COM it as well. Use factory-approved sealants and fasteners during refitment. You never know when it might be something odd and not obvious.
| Tags |
| 1996, 96, a3, a4, a6, audi, blinking, burning, check, flashes, flashing, gummy, light, oil, start |
