2.0 T Oil Usage
Old 06-07-2009, 07:19 PM
dlcole's Avatar
Default 2.0 T Oil Usage
I have 21,000 miles on my 07 A4 Cab. I seem to be using about a quart of oil every 7-8,000 miles. The warning light came on today, I checked the dipstick and it was a qt low. This has happened once before... This sure seems to be unusual for such a low mileage vehicle.
I have an .03 Chev, with 86,000 on it and it doesn't use a drop between changes.
At least Audi will get this one back in 12 months when the lease runs out and I won't have to deal with the problem long term...
David
Old 06-07-2009, 11:15 PM
Jer
Jer's Avatar
I have an '07 2.0T that is going through consumption tests as we speak. Sounds like I'm not the only one either.
Old 06-08-2009, 06:26 AM
AofC_RR's Avatar
It's fairly normal on the 2.0T.
Old 06-08-2009, 08:00 AM
Jer
Jer's Avatar
Yeah, it actually is and the service tech told me what the 'acceptable' level of used oil was per 5k miles and I was pretty shocked. I think it's a quart in 5k miles is considered within tolerance which is crazy that Audi considers that accepted.
Old 06-08-2009, 12:23 PM
chatta325's Avatar
Default same here
i've got an 07 a4 2.0t as well, and i have had it in for an oil consumption test... mine uses the same amount of ail as everyone here has stated...
Old 06-11-2009, 03:25 AM
tkken01's Avatar
Common issue for the 2.0T. My '06 A3 2.0T used a lot of oil and so does the '07 A4 2.0T. Buy a box of 5W-40 full synthetic and plan on topping off occasionally.
Old 06-15-2009, 01:44 PM
Car_Fynatik's Avatar
Very common problem on ALL turbo vehicles, one of the few cons to the benefits of a turbocharged system.
You are also not advised to run over 5k miles on oils in turbo vehicles because the oil gets filthy much faster than N/A cars. My 07 H3 averages 12k miles before the oil indicator says its about time to change it, and it doesnt burn a drop of oil, my turbo Honda has an engine I rebuilt & it consumes a little under a quart every 5k miles with only 20k on the odometer.
Old 06-24-2009, 03:10 PM
lfoley's Avatar
how often are guys changing the oil? I change mine every 3000-3500 miles and never used a drop
Old 06-26-2009, 05:21 AM
GermanCarBuff's Avatar
I change my oil every 5k miles, but even in that distance I noticed some oil consumption (1/2 quart or less) which as others have pointed out has been considered normal by Audi. Porsche also claims such oil consumption is normal in there cars too. It may be annoying, but as long as it does not get worse and it remains within the OEM tolerance, I would not be concerned.
Old 07-05-2009, 09:29 PM
wilson94t's Avatar
Default 1/2 quart in 5K
I'm seeing about 0.5 Quart in 5K miles, seems like this is par for the course. Mobil 1 0W-40 for now, maybe I'll change to something else and see if anything changes.
AirGibson
A4 (B8 Platform) Discussion
9
08-29-2018 11:12 AM
audi40
71
12-03-2017 06:38 AM
tonybah
20
03-07-2005 06:11 AM
DeTTroit
TT (Mk1) Discussion
18
02-19-2004 01:01 PM
geist
12-11-2000 10:35 PM
Quick Reply: 2.0 T Oil Usage
