Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 10-04-2004, 01:49 PM   #1
RoboEdar
Default interior lights flicker dim and bright.
i've got a 99 a4... w/ the all red gauge cluster, climate control, etc. and for some reason sine last week they are dim, and then they flicker bright and dim in random patterns. all of the interior lights flicker at the same time. if the gauge cluster flickers, then the climate control flickers at the same exact time blah blah....
i noticed that if i knock on the gauge cluster then it becomes bright for a few seconds...
any help guys?
RoboEdar is offline   Reply With Quote
Old 10-04-2004, 03:03 PM   #2
Nate (ETKA+Scumbag)
Keeper of the Cash
1997 Audi A4
Nate (ETKA+Scumbag)'s Avatar
Default If you have access to VAG-COM, run output tests on the IC as it will check dimmer operation via...
electronic control. It might also be a problem with the dimmer control on the IC. In that case you will want to remove and open the IC and check for lose or poor connections to the dimmer switch. I'm not 100% sure that it is the dimmer switch, it would just seem logical. If anything else, you might have a bad wire on the back of IC that supplies the signal to turn on the backlighting with your headlights.
"There might be intelligent beings created by God in outer space even if there are none here on Earth."
Nate (ETKA+Scumbag) is offline   Reply With Quote
Old 10-04-2004, 03:16 PM   #3
pcw
Default my car does the same thing! it's the dimmer post for the
interior lights. shake the post to see if you have the same problem i have.
pcw is offline   Reply With Quote
Old 10-04-2004, 03:24 PM   #4
Nate (ETKA+Scumbag)
Keeper of the Cash
1997 Audi A4
Default Good to know, thanks.
Old 10-04-2004, 03:41 PM   #5
ChooChooNongNongHead
Default yep, I have had the same problem...
mine eventually wouldn't stay bright at all, I took the cluster out and opened it to see if I could do anything. I used a can of compressed air a blew all around the stalk and connections and it worked fine for a few weeks...now its doing it again but not as often. I think the thing is worn out...wish i knew how to fix this.
ChooChooNongNongHead is offline   Reply With Quote
Old 10-04-2004, 04:48 PM   #6
Urban Rally
Default aw nuts, I thought this would relate to my prob, but mine's a little different:
Occurring in random intervals but always under a minute, most of the idiot lights, (don't have dash puter) will flash on then off, so quickly, that by the time you look down to see which one, it's gone. Car has been running fine since this is an old problem, I'm afraid to get it warrentied, since they'll say "failed to reproduce customer complaint" (think I've heard that enough to remember their script from the top of my head? lol) and then charge me the $50 copay. any Ideas anyone? kinda searched but the dash light thing came up not about idiot lights
Santorin 1999.5 Audi A4q Tip 30v - Traded for a
2006 Subaru WRX TR.
Urban Rally is offline   Reply With Quote
Old 12-15-2004, 06:14 PM   #7
fortemike
Default Solution?
I am having a similiar problem. My climate control cluster will flicker from dim to bright with the headlights on.
I was wondering if anyone came up with a definitive fix. I hate to give the dealer a blank check. Thank you.
fortemike is offline   Reply With Quote
96, a4, audi, bright, climate, cluster, control, dash, dim, flash, flicker, flickering, gauges, interior, lights, tt, turn
