epc... soft limp mode....
Old 05-12-2009, 06:58 AM
SemiProQuattro's Avatar
Default epc... soft limp mode....
my fiance was driving the car to work this morning and on the trip the epc light came on and the car lost power.... it started acting really strange. She pulled over and the car was idling really rough. She turned it off and then back on, the light was out and it was idling fine. She drove it the rest of the way to work and no other lights came on and the car was fine. Now i wont be able to vag it today.. hopefully tommorow.
Any ideas on what it could be or possible things to check or look for?
Old 05-13-2009, 05:20 AM
bump....
will vag today.
Old 05-14-2009, 03:23 AM
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 518 AK
Component: 1.8L R4/5VT G 0006
Coding: 0016711
Shop #: WSC 12596
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded - Intermittent
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal
17743 - Engine Torque Monitor 2: Control Limit Exceeded
P1335 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04275
Shop #: WSC 06435
1 Fault Found:
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AD
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
No fault code found.
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 00003
Shop #: WSC 63351
Address 15 -------------------------------------------------------
Controller: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
Shop #: WSC 63351
2 Faults Found:
01217 - Side Airbag Igniter: Driver Side (N199)
001 - Upper Limit Exceeded
00532 - Supply Voltage B+
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01041
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01231
Shop #: WSC 09108
WAULC68E74A247374 AUZ6Z0D0038079
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1512
Coding: 11788
Shop #: WSC 63351
Address 56 -------------------------------------------------------
Controller: 8E0 035 195 H
Component: symphony II PM6 0460
Coding: 00201
Shop #: WSC 00003
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
49-00 - No Communications
End -------------------------------------------------------
Old 05-14-2009, 03:28 AM
and then today while driving the cel came on.
still running fine, no power loss, no limp mode... **** is crazy
Old 05-14-2009, 07:37 AM
bump for any and all help
Old 05-14-2009, 07:36 PM
WoollyBugger's Avatar
a bad O2 sensor or MAF could cause all of your symptoms.
sometimes carbon builds up on the O2 sensors.
You can also check the connection with to your MAF.
i'm by no means an expert, you can try posting on Audizine where you'll def find more help
g'luck
Old 05-20-2009, 08:07 AM
02 sensor wouldnt cause that... but the maf/mass air would.
I went and cleaned the maf and reset the codes and lights... car is runbning fine. Hasnt acted funny since then.
am_ver
11
12-29-2010 04:22 PM
AzadA8
New England Discussion
01-18-2009 12:14 PM
bcx
12-13-2007 04:58 PM
Alan S
03-18-2006 10:31 AM
Quick Reply: epc... soft limp mode....
