#1 | ||
#2 | |
8E0 035 593/8E0 057 593 Sirius without RNS-E and without tire pressure monitoring system 8E0 035 593 A/8E0 057 593 A XM without RNS-E and without tire pressure monitoring system 8E0 035 593 D/8E0 057 593 D Sirius for RNS-E and/or with tire pressure monitoring system, works with Concert/Symphony as well 8E0 035 593 E/8E0 057 593 E XM for RNS-E and/or with tire pressure monitoring system, works with Concert/Symphony as well 8E0 035 593 F/8E0 057 593 F Sirius, MY 2007 8E0 035 593 H/8E0 057 593 H Sirius, MY 2007.5, single FAKRA antenna connector, needs splitter to work in older cars 8E0 035 593 L/8E0 057 593 L Sirius, MY 2008, single FAKRA antenna connector, needs splitter to work in older cars 8E0 035 593 G XM, MY 2007 8E0 035 593 N/8E0 057 593 N Sirius, MY 2008.5, single FAKRA antenna connector, needs splitter to work in older cars |
#3 |
Thanx very much for you help!
#4 |
atellite Radio Part # for 2007 Audi A4
Hey Everyone, I'm trying to locate a satellite radio module for my 2007 Audi A4. I called the dealer and they gave me the part numbers below but I'm a little confused because the part numbers on eBay are 8E0 035 593 which are listed for the Sirius radio but the dealer listed it as XM radio. Also I heard that the newer Audis only support Sirius but the dealer said that they have both modules that will fit my car. Anyway they want $500 for the module alone so I'm trying to find a better deal on eBay. Can you help me locate the right part number? My car is non bose, non satellite. Dealer Sirius - 8E0 057 595 D Dealer XM - 8E0 035 593 G eBay Sirius - 8E0 035 593 http://cgi.ebay.com/ebaymotors/AUDI-...QQcmdZViewItem http://cgi.ebay.com/ebaymotors/AUDI-...QQcmdZViewItem __________________________________________________ ________________ hgh Breast Augmentation Beverly Hills __________________________________________________ _______________ |
#5 |
ebay and the classifieds on here are the best places to find one of these for less. also, you might try looking at some of those auto salvage companies, some of them have nationwide searches.
#6 |
Installed a sat tuner number 8E0 035 593 D in my 07 A4. The factory prewire only included a single antenna connection. The 8E0 035 593 D has two connections for antenna. The radio now picks up the preview sat channels but the word antenna remains on the screen. Is this the result of my car only having the green connector and not the second connector which happens to be brown. Is there an adapter to correct this problem? Thanks in advance for the help!!
#7 |
Archie,
From what i hear there are two things you need. 1) you definately need to have someone with vag-com change the settings on your radio to show that you have SAT radio hooked up. From what i have heard, if you can hear the radio on one channel, but can not switch channels, then this is the symptom 2)I've heard this may or may not be needed to use an older unit with your newer car. I would try using Vag-com first, if that doesn't solve it, i would try ordering an adaptor like this. I THINK (might check on their return policy) this is the right part for a Fakra splitter. Good luck, and report back. http://kufatec.com/index.php?main_pa...oducts_id=1075 |
#8 |
also, FYI, here is the vag-com info page for your car.
if you have a II radio http://wiki.ross-tech.com/index.php/..._II#Adaptation II+ radio http://wiki.ross-tech.com/index.php/...lus#Adaptation |
#9 |
my older unit is a no go in a 2008 A4... only one sat connector in the car
#10 | |
| Tags |
| 035, 07, 2006, 2007, 593, 8e0, a4, audi, module, number, part, radio, satellite, sirius, xm |
