Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 04-25-2009, 07:47 PM   #1
camy2079
Default Help, engine starts then immediately Dies!
Hello,
I just bought a used 02 TT today. Ran great all day then I went to start it in the evening and all it did is start then immediately stops. The engine does run for 3-5 secs. I went and bought a new battery, no resolve. The keys are the original keys so I don't believe its related to the electronic immobilizer. BTW, the only thing done to the car before the issue is detail it.
Any thoughts? I'm extremely frustrated and plan on calling the seller tomorrow and ripping him a new one.
THX,
Charles
camy2079 is offline   Reply With Quote
Old 04-25-2009, 08:43 PM   #2
JohnLZ7W
JohnLZ7W's Avatar
sounds like the immobilizer. might need fresh batteries in the keys.
John
225QC
Aviator Grey/Ebony Cloth
Road Trip 2007 blog and gallery.
http://forums.audiworld.com/image.php?type=sigpic&userid=5201&dateline=1237605  682
"I just want to drive. I don't want to stop doing this, at all, ever" - Richard Hammond
"This is me breathing" - Martin Blank
JohnLZ7W is offline   Reply With Quote
Old 04-26-2009, 06:47 AM   #3
camy2079
Thanks!
New batteries, could it be that easy? I find it hard to believe this would prevent the car from running - design flaw IMO. I'll try that out...
Old 04-26-2009, 08:05 AM   #4
JohnLZ7W
JohnLZ7W's Avatar
That's the whole point of the immobilizer, to keep the car from running if the correct keys aren't used. There's a renegotiation sequence you'll need to do to retrain the car/keys when you put new batteries in. Don't remember it off the top of my head but you should be able to search for it here.
John
225QC
Old 04-26-2009, 10:27 AM   #5
AudiMick
2001 Audi TT
AudiMick's Avatar
Not sure about the 2002's but for a 2001 this answer makes no sense.
The battery in the remote/ key doesn't power the immobilizer.
The key comes in two pieces . Top part is remote with battery. Lower half is key with RFID chip (no battery). They are not electrically connected. The remote is just a remote.
I have 3 keys for my TT. One of them is a master key with no remote and thus no battery. Car works fine.
Check to see if the immobilizer light in the cluster comes on and turns off when the key is turned.
Also try the key both ways as sometimes if the signal is weak one position is better than the other.
If it's an immobilizer problem the motor will generally run for about 5 seconds.
Unfortunately if it is the immobilizer and you have only one it's a trip on a flatbed for you.
2001 180 TTQ coupe (sold)
1976 Triumph Spitfire
2008 A4Q 2.0T (sold)
2003 A4Q 1.8T (sold)
1996 A4Q (sold)
AudiMick is offline   Reply With Quote
Old 04-26-2009, 12:38 PM   #6
JohnLZ7W
JohnLZ7W's Avatar
Might just need to be re-synced then. Had similar problem with the 2003 in the garage, replaced batteries and did the handshake and all was well.
John
225QC
Old 04-27-2009, 11:53 AM   #7
FijiTT
FijiTT's Avatar
i had this happen with my 2002 with about 50k on it and the dealer could not figure it out for like 3 weeks. which was ok since i got a new a4 loaner. they replaced all kinds of stuff trying to fix it (cluster and so on) they ended up ordering me three brand new keys(2 with remote and one plastic). car started fine since then...
2002 TT 225 quaTTro coupe black/black 100k club
Mods: Bilstein sports, Neuspeed 19mm, EBC sport rotors, Greenstuff pads, Forge DV, wakk box with K&N, resonator and triangle on exhaust deleted, ecstuning 17.5mm rear spacers, modshack vent boost gauge pod, 3.2 rear valence, forge shift ****, redlinegoods leather shift boot
http://farm4.static.flickr.com/3360/3280519270_c54759a0d1.jpg?v=0
FijiTT is offline   Reply With Quote
Old 04-27-2009, 02:44 PM   #8
Michigan TT
welcome
Michigan TT is offline   Reply With Quote
Old 04-28-2009, 04:37 PM   #9
camy2079
Thanks for the advise everyone! I got up the next day and tried starting the car and it started up fine. No issues since then, not sure what to think.
Charles
Old 05-13-2009, 03:15 PM   #10
camy2079
Ah... It's back. Would not start 3 times today while out running errands. I had my mechanic take a look and he didn't find anything wrong.
Aside from the key fob, what else could it be?
Thanks!
2000, 2001, 2005, a4, audi, brakes, car, dies, engine, immediately, immobiliser, starts, stops, tt, work, wrong
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
