Are these symptoms of a bad alternator ?
Old 04-24-2009, 08:11 PM
kgrig's Avatar
Default Are these symptoms of a bad alternator ?
First of all normally when the car is running, the voltage on the dash meter reads around 14V. Today I had trouble starting it but got it started and the voltage was around 12V with the car running. Then I drove it home and next time it didn't start. Had it jumped, and it started but the voltage was reading around 10V. When I turn on the headlights it drops to almost 8V on the indash meter. If I'm driving real fast on the highway it reads around 11V.
I think it's the alternator but want to double check to make sure. I thought the alternator was a gradual failure, with me it just seems like it died overnight.
If it is, I have an 01 2.8Q with ATQ engine code and 8GL option. That means it's a 120A. Is there a way to tell if it's Valeo or Bosch? (Do I have to change out the alternator completely, or can I just change bushings, etc?)
Also, is this job difficult to do on the 2.8L?
Thanks!
Old 04-24-2009, 08:36 PM
viceprp's Avatar
Sounds to be the alternator.. When mine went in the b5 i just changed it, i dont mess with the bushings. Sounds like your just runnin on your battery mostly
Old 04-26-2009, 07:27 PM
kgrig's Avatar
Default Is there a way to tell if the altnernor is valeo/bosch without taking it out?
can it be figured out from the options? I know that it's a 120A alternator based on the option code on the trunk sticker.
Old 04-27-2009, 03:03 AM
Tech Guru
4Driver4's Avatar
Not really. Most 2.8's had Valeo. You'll need to put the nose into service position and pull it out the front.
Old 04-27-2009, 03:15 PM
kgrig's Avatar
for anyone that cares....mine turned out to be a bosch one
silentpeat
09-06-2010 04:29 PM
1-pippin
09-26-2008 04:07 AM
SpyderMR
Audi allroad
18
06-28-2008 01:36 PM
deedza
03-19-2008 05:13 PM
Jimmy TJ
01-03-2002 10:34 AM
Quick Reply: Are these symptoms of a bad alternator ?
